$70 7" Android: Almost Time to Buy?
http://cgi.ebay.com/Eken-M009S-7in-Android-Tablet/190574152357?_trksid=p1468660.m2000036
Here's a 7" touchscreen Android 2.2 OS for $70 shipped from a US seller. When they get down to $50, that's not much more than you'd pay for a digital picture frame. THEN I'll use it as a chassis for a mobile robot.
How long before they're "Buy It Now" for $50? Before Christmas, I'll bet.
If it had Bluetooth I would buy one.
Bean
Any idea how much memory the micro SD card slot can access? If it is capable of reading a 32 GB card then you might have something here.
Is there any chance you can upgrade Android on this unit?
How does it compare to full price models?
Any idea on how long the Litium Ion battery would last?
Where would you get the aps for it and what kind of aps come with it?
Can I read/write Microsoft Word files with this?
What do you use the 30 pin connector port for?
Sorry for all the questions. Thank you.
Upgrading the OS version on an Android tablet can be done, but Android is not like Windows. The tablet vendor or a helpful third party needs to compile the sources for your tablet. This tends to only happen for more popular tablets like the Nook or Galaxy Tab.
No idea how long the battery lasts. The 30 pin connector is probably for a keyboard doc, but don't count on that being available in the US.
1600mAh is a surprisingly small battery though. For such a large device I would have expected something better (there should be room for it). The 1250mAh battery in my Android phone lasts some 3 days if I don't use it.. (no SIM card, no or very little wi-fi usage), and that's when running a (compared to the original) much improved 3party Android w.r.t. battery usage - the 2.1 it came with would last just over a day.
My OpenPandora handheld has a 4000mAh battery.. and it's much smaller.
-Tor
SD caps at 4 GB and If the card is more then 4 then its SDHC and this applys to the mini card and the full cards and micro cards .
but Yes the OS one would hope support it . but be aware the HW has to also ...
and 2 TB is SDXC ...............
The hardware doesn't have to support SDHC as such, there are no hardware differences between SD and SDHC. It's all in the driver. As for SDXC, that's just a technicality, a decision by the SD consortium to do some changes instead of just using the full potential of SDHC. SDHC works all the way up to 2TB (if only someone would make such cards). It's only about how many addressing bits the card uses, and it can use all the way up to cover 2TB. And if a card does, then the driver in the Android Linux kernel would handle it. SDXC came about for two reasons:
1) FAT32 isn't a good filesystem for such large cards.
2) With all the data on large cards it would be preferable with higher speed.
For 1) there's exFAT, but you can also just format the card with a Linux filesystem, and that would work for Android.
For 2) it's done in two steps: The initial SDXC specification isn't changed from SDHC, you can read such cards with the old hardware (the 3.0 specs). The next level (4.0 specs) has twice the number of data pins so that the bandwidth can increase, for these SDXC cards you would need different hardware.
So the difference between SDHC and SDXC for the initial 3.0 specification is only about the default filesystem really.
I agree with Bean. I have one of these and I have programmed it with Basic4Android and it is very clever the way you can program it wirelessly with wifi. But you can't control anything with these things - no real world I/O. The best I got was simulating a RS232 signal through the audio output, but even that is a fudge because it has to write the file to the SD card just to play it, so that wears out the SD card.
Lots of drivers don't work either, including a USB keyboard, USB to serial device and Bluetooth dongle.
It makes a good music player though.
I think it is all going to come together over the next year or two, but it isn't quite there yet.
Have you tried M.K.Bori's Android Debug Bridge. As far as I understand that gets you effectively a serial link between Prop and Android device with only a couple of resistors required.
https://www.sdcard.org/developers/tech/sdhc/
Peter...
This page spells it out a bit better than I'm able to - my English isn't good enough.
http://en.wikipedia.org/wiki/Secure_Digital#SDHC_and_SDXC_compatibility_issues
the one In my toughbook is a USB reader on the host tree so it is fixed to what FIRMWARE is coded on the host controller .
as far as I can atest .,. I have never got it to read my 32GB SDHC card .
but the mac can . and as Your cited link says . Linux can do all of the specs out right now ..
so yes there can be a hardware limit depending on how the card is attached to the computer
and who makes the controller too .. BTW my 16 works great . so
my worry was the CHEAP tablet may not have a full spec controller . ..
SD the most jacked up standard there can be ..
that and USB ..
the unstandard standards .
Yes, a card reader, with its built-in firmware (i.e. its driver software) can be limited to just SD and unable to read SDHC. But an Android device will be designed with a reader slot of the type used with e.g. propeller boards, and it doesn't contain any firmware - it's just the electrical interface. It won't make sense to build a card reader like the stand-alone ones into the device, it'll be much more expensive. The Android devices can always rely on having a driver ready available, because they're all running Linux kernels. And they don't suffer from SD-only limitations - it'software.
(don't get me started on USB though.. now _that's_ indeed a messed-up standard! :-))
-Tor
Eureka - this is the missing link!
http://hackaday.com/2011/03/29/propeller-android-communications-using-debug-mode/
http://robots-everywhere.com/re_wiki/index.php?title=PropBridge
And there is a little throwaway line in the description
This is one of the downsides of the android tablet - it uses a lot of power. But you may not need it on all the time, so if the propeller can send the android to sleep for a while, that means your solar powered robot can rest overnight without flattening the batteries.
Android - Strengths = great display, wifi, lan, great value for all these things. Weaknesses = uses a lot of power and no decent real world interface.
Propeller = able to shut down to almost zero power consumption, fantastic range of real world I/O. Weakness - no decent display with an easy to use GUI.
Combine the two together though, and we have a very interesting combination.
Hello!
Sadly erco the price as listed then was $199, and it now says "This listing was ended by the seller because the item is no longer available.", which means that the vendor took it off the market. (Which is strange because supposedly almost anything is available there.)
