Boe-Bot: Continuous forward until any key is pressed.
Continuous Forward
When using the Parallax provided TerminalBoeBotControl_Keypad.bs2 file, I am attempting to modify the forward command (for instance) to make the Boe-Bot run forward continuously until any other key is pressed to stop the continuous forward movement. In other words, I am trying to implement a LOOP function, that, when ends, returns to the Main routine. I have attempted many methods as to using DO|WHILE LOOP, but have not been able to achieve the desired results. Below is the original code.
' TerminalBoeBotControl_Keypad.bs2
' Moves the Boe-Bot based on the numbers 2, 4, 6, 8 or the
' letters A, W, D, X.
' {$STAMP BS2}
' {$PBASIC 2.5}
RX PIN 2 ' RX of the Easy Bluetooth
TX PIN 0 ' TX of the Easy Bluetooth
ltServo PIN 13 ' Left Servo Pin
rtServo PIN 12 ' Right Servo Pin
FwdLtFast CON 850 ' Left servo forward full speed
BwdLtFast CON 650 ' Left servo backward full speed
FwdRtFast CON 650 ' Right servo forward full speed
BwdRtFast CON 850 ' Right servo backward full speed
Baud CON 84 ' Baud set at 9600
myByte VAR Byte ' Byte to establish connection
index VAR Word ' READ index/character storage
character VAR Word
dirChar VAR Word ' Stores directional character
counter VAR Word ' Counter for FOR...NEXT loop
DATA CLS,
" ", CR, ' 14
" ", CR, ' 28
" | ", CR, ' 42
" --o-- ", CR, ' 56
" | ", CR, ' 70
" ", CR, ' 84
" ", CR ' 98
PAUSE 250 ' Waits 1/4 second
SERIN RX, Baud, [myByte] ' Waiting for byte
myByte = 0 ' Clear the byte value
' Display background
FOR index = 0 TO 99
READ index, character
SEROUT TX, Baud, [character]
NEXT
' Let user know the program is running
SEROUT TX, BAUD, [CR, CR, "Program Running..."]
DO
' Recieve character from the PC
SERIN RX, Baud, [dirChar]
IF (dirChar = "8") OR (dirChar = "w") THEN
GOSUB Forward
ELSEIF (dirChar = "2") OR (dirChar = "x") THEN
GOSUB Backward
ELSEIF (dirChar = "4") OR (dirChar = "a") THEN
GOSUB Left
ELSEIF (dirChar = "6") OR (dirChar = "d") THEN
GOSUB Right
ENDIF
LOOP
Forward:
SEROUT TX, BAUD, [CRSRXY, 7, 0, "*", CRSRXY, 6, 1, "*", CRSRXY, 8, 1, "*"]
PULSOUT ltServo, FwdLtFast
PULSOUT rtServo, FwdRtFast
PAUSE 20
SEROUT TX, BAUD, [CRSRXY, 7, 0, " ", CRSRXY, 6, 1, " ", CRSRXY, 8, 1, " "]
RETURN
Backward:
SEROUT TX, BAUD, [CRSRXY, 7, 6, "*", CRSRXY, 6, 5, "*", CRSRXY, 8, 5, "*"]
PULSOUT ltServo, BwdLtFast
PULSOUT rtServo, BwdRtFast
PAUSE 20
SEROUT TX, BAUD, [CRSRXY, 7, 6, " ", CRSRXY, 6, 5, " ", CRSRXY, 8, 5, " "]
RETURN
Left:
SEROUT TX, BAUD, [CRSRXY, 3, 3, "*", CRSRXY, 4, 2, "*", CRSRXY, 4, 4, "*"]
PULSOUT ltServo, FwdRtFast
PAUSE 20
SEROUT TX, BAUD, [CRSRXY, 3, 3, " ", CRSRXY, 4, 2, " ", CRSRXY, 4, 4, " "]
RETURN
Right:
SEROUT TX, BAUD, [CRSRXY, 11, 3, "*", CRSRXY, 10, 2, "*", CRSRXY, 10, 4, "*"]
PULSOUT rtServo, FwdLtFast
PAUSE 20
SEROUT TX, BAUD, [CRSRXY, 11, 3, " ", CRSRXY, 10, 2, " ", CRSRXY, 10, 4, " "]
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
character VAR Word
DATA CLS,
" ", CR, ' 14
" ", CR, ' 28
" | ", CR, ' 42
" --o-- ", CR, ' 56
" | ", CR, ' 70
" ", CR, ' 84
" ", CR ' 98
FOR index = 0 TO 99
NEXT
DO
GOSUB Forward
GOSUB Backward
GOSUB Left
GOSUB Right
ENDIF
LOOP
Forward:
PAUSE 20
RETURN
Backward:
PAUSE 20
RETURN
Left:
PAUSE 20
RETURN
Right:
PAUSE 20
RETURN
Andy? You around?
-Matt
' {$STAMP BS2} ' {$PBASIC 2.5} pulse VAR Word maneuver VAR Word FREQOUT 4, 2000, 3000 DEBUG "8 = forward", CR, "2 = backward", CR, "4 = rotate left", CR, "6 = rotate right", CR, "5 = stay still" DO SERIN 16, 84, 20, Timeout, [maneuver] Timeout: GOSUB Go LOOP Go: LOOKDOWN maneuver, ["5", "8", "2", "4", "6"], maneuver LOOKUP maneuver, [750, 850, 650, 650, 850], pulse PULSOUT 13, pulse LOOKUP maneuver, [750, 650, 850, 650, 850], pulse PULSOUT 12, pulse RETURNP.S. That was fun. I added a post about it to our Stamps in Class "Mini Projects" thread in the Boe-Bot Robot section.
What's the word? Any progress, and did Andy's code help?
Oh, yeah - and welcome to the Forums!
-Matt
