Blue Wolf FlashFly USB Kit Ready To Go
Just installed the Flash Fly USB modules. As advertised, it worked right out of the
box.... "worked" meaning using the X-CTU software, it detects the modem.
I am able to receive messages being sent from the Stamp and I am able to send/receive
text from the terminal tab. HOWEVER, when I try to load a program from the
Stamp Editor (V 2.5.2), I get the "No Stamp Found" message. The form has a hit but
it refers to a DTR line that must be connected to ATM. The references schematic
on pg 28 of the Basic Stamp Ref refers to a USB to serial adapter. I don't have any
serial connectins. The BOE is a USB devise and the remote XBEE board is the
USB adapter that uses the FTDI USB serial interface chip. I'm using Windows 7
which supports this device.
Do I need to do something in the setup to allow the BOE to recognize the Basic Stamp
on the Flash Fly adapter board ???
into the project, you have to use the Basic Stamp Editor (Run > Identify > Refresh) to find the XBEE
comm port.
In the Stamp Editor software, please try going to the "RUN" Menu, then the "Identify" option under that menu. Be sure to only enable the "COMM" port that shows up for the USB Base device. Please refer to the FAQ on the site if you need further help. http://www.bluewolfinc.com/flashfly-faqs/ - Thanks
