Prop proto board USB & servos
I'm working on my first proto board and I'm trying to use the servo circuit. I've soldered in the 4 headers for the servos and the header for the power selection and added a jumper to select 5 volts but I'm not getting power to the servos, I measured the voltage between the ground pin on the servo header and the middle pin and I'm not getting power. Any ideas on what went wrong or what I'm missing?
