PST work with BST?
PST is not working with the serial terminal in BST.
Are these fully compatible?
If it should work, I'll post more details.
what exacly do you mean with PST is not working with the serial terminal in BST?
BST has its own serial terminal to receive serial data from the propeller.
So you don't need an extra serial terminal. You can even jump between BST-editor downloading code and BST-implemented serial terminal automatically:
opening and closing the serial port is done automatically by BST.
Or do you mean the PST-object - the SPIN-code for the propeller?
For this pair the parameter must be configured the same.
Baudrate and mode.
Please write more about your configuration and the results you get.
keep the questions coming
best regards
Stefan
'' '' Parallax Serial Terminal '' Control Character Constants ''───────────────────────────────────── CS = 16 ''CS: Clear Screen CE = 11 ''CE: Clear to End of line CB = 12 ''CB: Clear lines Below HM = 1 ''HM: HoMe cursor PC = 2 ''PC: Position Cursor in x,y PX = 14 ''PX: Position cursor in X PY = 15 ''PY: Position cursor in Y NL = 13 ''NL: New Line LF = 10 ''LF: Line Feed ML = 3 ''ML: Move cursor Left MR = 4 ''MR: Move cursor Right MU = 5 ''MU: Move cursor Up MD = 6 ''MD: Move cursor Down TB = 9 ''TB: TaB BS = 8 ''BS: BackSpace BP = 7 ''BP: BeeP speakerMost serial terminal programs, including the one in BST, do not recognize all of these. Many of them are not standard control sequences. Only the PST PC program recognizes all of them.Mike Green:
Thank you for your reply. This is precisely what I need to know. The PST object was sending control sequences which the BST serial terminal did not recognize.
