Help with game stick — Parallax Forums
TappermanTapperman Posts: 319
edited 2011-09-01 10:25 in General Discussion
I came across an old 'Flight Stick' (apx 10-15 yrs old) and I was hoping that before I opened up, maybe someone out there had a clue as to it's wiring?
I think it was designed to plug into the old 'Game' port on IBM PC's ... and I used to have a pin out description of that standard, but alas, that was many 'moves' ago .... Does anyone have that old port standard data?
Thanks in advance,
... Tim
PS - http://forums.parallax.com/showthread.php?133911-Assembler-Question&p=1030312#post1030312 I plan to use it on my Go-Kart
    edited 2011-08-31 13:25
    Will this help?
    http://pinouts.ru/Inputs/GameportPCMidi_pinout.shtml
    Or do you need more?
    OBC
  • TappermanTapperman Posts: 319
    edited 2011-08-31 14:03
    Nope ... That's it!
    Thankyou!
    ... Tim
    edited 2011-08-31 15:28
    A fairly critical application. Can't go wrong with real throttle parts from http://www.tncscooters.com or http://electricscooterparts.com
    Hey ... I actually enjoy a good challenge, this is actually the throttle that I have planned for the Go-Kart:
    With Mr. Schwabe's work on inductors, I was able to adapt an object you saw in the above demo.
    It's a hand wound coil on a 5" piece of PVC (apx 50 turns) and I read it with an object I wrote that finds the center of the LC tank ... I read it from 1KHz less than the returned center (never 'chasing' the center), and the results read at that point are very linear!
    My physics instructor thinks the 'non-linear' reaction of the inductor is countered by the non-linear reading of the device .. and the two functions are anti functions of each other.
    I also like the 'ruggedness' of this throttle ... you can stick it in the mud, and then slide it through and it is not affected (at least that I can detect). My RC throttle works, but would never survive the rain outside.
    Who's to say, I don't have a REAL throttle part. Would you say it was fake?
    ... Tim
