Stumpped! — Parallax Forums
Stumpped!
RS_JimRS_Jim Posts: 1,775
edited 2011-09-02 22:23 in Propeller 1
I have been working on this concept for a servo using a stepper motor for about a week now. Must admit this is my first major undertaking in Spin. I normally work in PASM. when I enter a step count value of 1 to 99 all goes well. When I enter a value of 100 or above it crashes! What I mean by crash is the stepper momentarily hums loudly, steps 2-3 steps and stops. From there on, the data entry screens work fine but the stepper will step just 1 time and stop. When I use a fixed value for Value without keyboard entry the repeat loop works fine and the motor steps the required 100+ times.
Do I need to put the obj serv.step in a new cog? Why does it crash with a keyboard entered value and not with an entered constant?
CON
  _clkmode = xtal1 + pll16x                  ' System clock → 80 MHz
  _xinfreq = 5_000_000
con
  RX1 = 31
  TX1 = 30
  SDA = 29
  SCL = 28
  XOUT  = 7
  YOUT  = 6
con
   #1, HOME, GOTOXY, #8, BKSP, TAB, LF, CLREOL, CLRDN, CR       ' PST formmatting control
  #14, GOTOX, GOTOY, CLS
   _stack [ 65]
VAR
 Byte Valstr
 Long Value
 Byte instr[49]
' Long tGrowth
OBJ
  term       : "FullDuplexSerialPlus_Plus"       ' Variable & I/O display tool
  rc         : "RC_Time_ASM"                     ' RC Time is also an option
  stepserv   : "Jimsstepper"
  nums       : "Numbers"
 ' schematics : "Schematics"                  ' Circuit Schematics
 ' terms      : "Terms of Use"                ' Terms of use
PUB Main | idx ,tGrowth , adjust, x , y
  ' Set up Parallax Serial Termial display
  term.start(RX1, TX1, %0000, 115_200)                          ' start serial
  stepserv.start
  nums.init
  rc.start(1, 0, clkfreq/1_0000, clkfreq/2000, clkfreq/1000,@tGrowth)
  waitcnt((clkfreq / 1_000)*2_000 + cnt)
  term.tx(CLS)
  term.str(string("Step Servo Test V1"))
  term.str(String("Time Measurements units = 12.5 ns"))
  term.tx(CR)
  term.tx(LF)
  term.str(string("----------------------------------------"))
 prntStr(tGrowth)
 waitcnt(clkfreq/10+ cnt)
 repeat
  'term.tx(CLS)
    prntStr(tGrowth)
    term.tx(CLREOL)
    x :=0
    bytefill (@instr,0,45)
    repeat until x== "+" or x== "-"
      term.tx(GOTOXY)
      term.tx(20)
      term.tx(4)
      term.str(string(" Enter + or -  "))
      x := term.rx
    term.str(string("Enter number of steps "))
    term.tx(CLREOL)
    term.getstr(@instr[0])
    Value := nums.FromStr(@instr[0],%1010)
    term.tx(CLRDN)
    dec3(Value)
    term.str(string("  "))
    repeat  idx from 0 to value
      IF x == "+"
        stepserv.HalfstepFwd
      Else
        stepserv.HalfstepRev
      waitcnt(clkfreq/100+ cnt)
      idx++
      dec3(idx)
    term.str(string(" done "))
Pub prntStr(n)
    term.tx(GOTOXY)
    term.tx(0)
    term.tx(4)
    term.str(String(" Servo Position  "))
    dec3(n)
pub dec2(n)
  if (n < 10)
    term.tx("0")
  term.dec(n)
pub dec3(n)
  if (n < 10)
    term.tx("0")
  if (n < 100)
    term.tx("0")
  term.dec(n)
PUB pause(ms) | c
  c := cnt                                   ' sync with system counter
  repeat until (ms-- == 0)                   ' repeat while time left
    waitcnt(c += clkfreq / 1000)             ' wait 1 ms
    edited 2011-08-31 10:02
    Jim,
    Have you debugged Value to verify what it is after keyboard entry? I would recommend debugging what Value is after entering 100 manually.
  • RS_JimRS_Jim Posts: 1,775
    edited 2011-08-31 10:31
    Chris,
    Thanks for quick reply.
    The line "dec3 (Value) is the debug line and it prints the exact same number that I input Value from the terminal or when I equate Value to a constant. I also use code later down to display the value of idx on each iteration of the loop. Though it only displays every other value of idx (1..3..5..7 etc.) it is reaching the correct end Value. I am going to start setting up jimstepper as a seperate cog and try to do it in PASM. I am going to try to synchronize full and half steps so that I can switch between them on the fly to speed up or slow down the step rate with out crashing the motor. I will probably pass to it info to give it step direction and type ie "a" half step forward "b" full step forward, "c" halfstep reverse. FYI the motor is the Parallax stepper driven by a ULN2003 and using an 88 theeth 48 pitch gear on the pot. By the way, on the spec sheet for that motor it says theholes are 4-40 I think they are metric 3-50'
    Jim
    edited 2011-09-01 09:09
    Sorry Jim, my efforts to help were delayed by not having the original archive. For example, I don't have FullDuplexSerialPlus_Plus that you reference. But I do think I see an error in your debug value. So let me see if I can recreate it with what I do have and post back.
    edited 2011-09-01 09:38
    My mistake...the debug routine is fine, it's just the way it was done that threw me off...however I did notice that when the steps actually occur, debugging the current index shows it jumping from 1 to 3 to 5 to 7 to 9 when I say to move 9 steps. So when I enter 9 it's really only moving 5 steps. Are you seeing this as well? Again, I had to hack my code to simulate what I don't have, so I may have made a mistake in guessing functionality.
    So anyway with a value like 9 or 99 steps it ends on that idx value, however entering 100 causes it to go to 101. I would recommend taking out the Idx++ statement. For me that seems to fix the counting issue as you're not adding an extra count every pass through the loop, skipping values. Let me know what happens.
    edited 2011-09-01 15:56
    Jim,
    You might want to look through the object "Numbers". It has methods you recreate in your program (zero padding).
    I ought to take my own advice. I saw several methods that I frequently add to my programs (only my methods don't look as nice as the ones in "Numbers").
    Duane
    edited 2011-09-02 05:59
    Chris,
    Ok I removed the idx++ and that solved the skip step issue. However, when Value goes over 100 from keyboard entry the program goes off in a strange direction. I don't have the program with me at the moment but when I do, I will archive it and attach.
    Duane, I will be blowing the dec away once I have the bugs worked out, but I will look more closely at numbers.
    Thanks for looking into things.
    Jim
    edited 2011-09-02 09:08
    Jim, I dug out my Demo Board (I usually use the PPDB) and downloaded your code. One thing I noticed is that the stepping speed changes when you go over 100 with the step values. That shouldn't have any affect on that. Also, your program lists the initial position as 400, but no matter how many steps I make in either direction, that never changes. One last observation. Once you enter a number of steps that number is printed first before the 0 through index values. I didn't see anything that should cause that, but I will take a quick look at the code right now.
    edited 2011-09-02 09:28
    Ok, making a little more headway...it seems the code changes speed only for a 3-digit value...any 3-digit value. One, two, four or five digit values seem to work fine.
    edited 2011-09-02 10:20
    Okay, I haven't figured out why yet, but I have found what I believe to be the cause of the timing issue when a 3-digit value is entered. It seems to be related to FullDuplexSerialPlus. If you manually set Value before the steps are done the problem persists, however if you take the getstr out of the equation the problem goes away. So something weird is happening when that routine is called. The funny thing is it actually adversely affects the timing of the waitcnt in the step loop causing it to run at a weird speed.
    edited 2011-09-02 11:11
    Okay, the problem definitely seems to be related to the FullDuplexSerialPlus.spin function, getstr(). I noticed when this line was commented out things seemed to run properly, regardless of hard coding Value. Debugging the assumed values returned by numbers didn't seem to indicate a problem, but when you debug the array itself you find that when getstr() returns, the array contains and extra value. Here's the values after entering 49 for the number of steps.
    52
    57
    13
    0
    As you can see the 13 (Carriage Return) is now part of the value. I'm not sure why the count still comes out right, but this is not what is expected. I contacted the author regarding FullDuplexSerialPlus and he says that this object is obsolete and was known to be buggy and that customers should be using the replacement object included in the Propeller Library called, "Parallax Serial Terminal.spin". Please note there are a few differences, for example getstr() is now StrIn().
    Let me know if this solves your problems Jim, and sorry for the delays, but this one was a tough one for sure.
    edited 2011-09-02 11:41
    Jim,
    Try changing:
    to:
    Value := term.getdec(@instr[0])
    The method "FromStr" in numbers is to complicated for me to follow.
    I could understand the "getdec" method in FullDuplexSerialPlus. It should ignore the carriage return character.
    I haven't tried this but my gut is telling me it should work. (Either that or I'm hungry.)
    Duane
    edited 2011-09-02 12:01
    Duane Degn wrote: »
    Duane
    Duane,
    I think you're just hungry since GetDec doesn't require parameters. :innocent:
    Edit: I forgot to mention that was one of the first things I tried, but alas the code still goes wonky for timing when using this.
    edited 2011-09-02 12:15
    I blame this (my mistake, not the lack of parameters in GetDec) on low blood sugar.
    Duane
    edited 2011-09-02 12:52
    When you enter +0 or -0 it still increments or decrements the sequence. Shouldn't it remain in the same position?
    The repeat loop that you have starting with "0" and ending at the number that you give it will always increment an additional Half step. i.e. 0 to 100 is actually 101 positions
    edited 2011-09-02 19:39
    For the record, the getstr method silently corrupts memory (FullDuplexSerialPlus_Plus).
    PUB getstr(stringptr) | index
        '' Gets zero terminated string and stores it, starting at the stringptr memory address
        index~
        repeat until ((byte[stringptr][index++] := rx) == 13)
        [COLOR="red"]byte[--index]~[/COLOR]
    That should read (taken from FullDuplexSerialPlus):
        index~
        byte[COLOR="orange"][stringptr][/COLOR][--index]~
    Chris,
    Thanks for all your hard work in tracking down the source of the problem. I changed from FullDuplexSerailPlus_Plus to Parallax Serial Terminal, and after a bunch of edits to correct the interface to the new terminal all works well! I now have to carry this information into my PASM stepper driver. I wonder if I was passing trash to it as well. I did find out along the way that my prop tool was out of date and I had to up grade it along the way.
    Kuroneko,
    Thanks for pointing out the bug in FullDuplexSerialPlus_Plus, I will go on a search and destroy mission to remove all copies of it from my systems.
    In some quick testing of the system, it appears for this to work accurately, I may have to revert to using an ADC to handle the post values quickly enough.
    I can now change the status of this post to solved.
