Burnin on μOLED-128-G1?
I had my μOLED-128-G1 attached to one of my projects displaying readings for a few months.
Unfortunately I didn't consider the relatively static display would result in burn-in.
It's noticable but not too bad...
My question being, is there any one to get ride of the burn-in?
Jay
Jay
I'm assuming the burn in is the affect of the affected LEDs losing brghtness over time,
Would de-rating the pixel current to dim the display prevent the loss brightness?
The manual recommends dimming and changing the text to prevent burn-in. Obviously a little late now,
I'm just new to OLED and was wondering if there's some 'trick' to getting the display corrected. Hmm... I should try gray instead of black ;-)
In the end its all "good" (relatively speaking) as its lessons learned...
Jay
Jay,
Unfortunately, these devices suffer from a substantially faster burn in rate than the old monochrome monitors. I had two uOLED-96-PROP's running a static display for two weeks, and they are toast. There is nothing that can bring them back from what I have read.
Welcome to the club
EDIT: I just saw your post after I did.
