What is on the output pins in TV (composite video) mode?
Are the output pins in TV mode (NTSC and Pal) still purely digital switching between 3V3 and Gnd?
I realise that they are phase shifted, etc. Is the pulse width being used to create an analog voltage?
My question arises because I want to be able to switch them between purely digital I/O pins and TV out pins.
My preference is to use 74LVCxx gates to switch, but maybe I need to use an analog switch IC. If I need to use an analog switch, any suggestions?
Yes.
No. The analog voltage is purely a product of the resistor DAC.
The phase shift is just a change in the output on a sub-pixel frequency. No pulse width / duty analog coding unless you're using one of the one-pin drivers. I'm not sure you even need a switch, see http://forums.parallax.com/showthread.php?133688-VGA-TV-DAC-using-resistor-arrays-(and-other-uses)&highlight=resistor+network
-Tor (following another project which is constantly suffocating from if-there-were-just-a-few-pins-more..)
(But then the impirical values do not give a true 75 Ohm feed as has been documented before)
