Crystal question; where to get a SM one like on the Propeller Backpack?
Hello,
I'm working on my first PCB project with SM parts and I was trying to find a 5mHz clock crystal that's the same size/packages as the 6.25 crystal that's used in the Propeller Packpack. Adding to my question,I've been looking on Mouser and they have two categories "crystal" and "oscillator". I've looked at the data sheets here and I can't figure out which one I need. Any suggestions? Thanks!
Propeller Backpack:
http://www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/SortField/0/Level/a/ProductID/602/Default.aspx
Clock I need, but just SM and smaller:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/Crystal/List/0/SortField/4/ProductID/341/Default.aspx
Propeller Backpack:
An oscillator contains other components and will generate a clock signal on its own, if it's supplied with power.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=XC1720TR-ND
C.W.
About .12" x .35" plus the leads.
See:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=300-2072-1-ND
Duane
I've used this one too and it works quite well.
