Spinneret Document: {in raw form} for review
Oldbitcollector (Jeff)
I'm going to go ahead and post this here instead of the "official" Spinneret section as I've been seeing threads pop up recently with questions which the Spinneret would make a good solution.
I'd appeciate review and comments on the current version of this document. It is still in "raw" form and hasn't had a good pass through editing, but the material itself feels solid.
Currently it contains the following:
Understanding Internet Network Requirements as pertaining to Spinneret.
Howto Configuration of BASIC Spinneret webserver software (Mike G Software)
Basic configuration of "port forwarding" with common routers.
Addendum #1: Using Spinneret with DynDNS services
Addendum #2: How to use PROPbasic with the Spinneret
Addendum #3: Email notification from the Spinneret
Addendum #4: Controlling "Real world" I/O from a Spinneret webpage.
Thanks!
OBC
Thanks!
OBC
I would note that the IP addresses you mention are IPV4 and that is within the scope of your document. Much of the world uses IPV6 for hosts these days. Does Spinneret support IPV6? If not you should mention it.
Thanks!
OBC
http://code.google.com/p/spinneret-web-server/source/browse/#svn%2Ftrunk%2FMultiSocketServer_MikeG
I'll add a reference to the Google repository on the agave site.
to
I would also include a link in this section to a reference,
http://en.wikipedia.org/wiki/IP_address
for example lists the rfc's etc
Great Document! Now I just need the spinnernet!
Page 13 of your doc near the bottom " go to my SPAM folder" should probably read "going to my SPAM folder"
Jim
edit: On thinking about it, that seems like a daft question: the answer would be to remove the card, put it in a PC and transfer the file. Still, it might be nice to have a few words on the formatting options, eg whether it's safe to use subdirectories.
