The touch buttons on the QuickStart are specifically designed so that they do not affect with the I/O pins, unless they are specifically being read. For more information about the hardware on the QuickStart, see its page at http://www.parallaxsemiconductor.com/products/quickstart and click on the "Specifications" button near the bottom.
So nice of you to give me an excuse to put in a plug for my new robot. I'm using P0 through P5 for the Nordic transceiver.
Not only don't the touch pads interfere with the IO pins but the LEDs use a buffer so they don't interfere with the IO pins either. It's kind of cool to use the LED pins for other purposes and see them turn on and off with the activity of the pins.
I am using a rather old 24x1 LCD with data being output to the LCD on those P0..P7 lines. And since the LCD uses an Enable line to load/clock in the data/commands, I am free to use those low 8 lines for other input/output use.
— David Carrier
Parallax Inc.
Duane
