Position Controller Serial communication problems... — Parallax Forums
BamseBamse Posts: 561
edited 2011-09-01 08:59 in Robotics
Howdy...
I'm using the wheel kit that comes with the position controllers (#29319) and some code that queries these encoders in a loop.
This loops works anything from 1 minute up to 15 minutes and then it get stuck on one of the PosCtrl.rx calls.
PosCtrl.tx(QPOS+1)
wheel_pos1.BYTE[1] := PosCtrl.rx <==== Get stuck in one for the PosCtrl.rx
wheel_pos1.BYTE[0] := PosCtrl.rx
Unfortunately the Simple serial does not seem to support any timeout functionality so I need to figure out how to "unhang" the call to PosCtrl.rx
A quick test with Full Duplex Serial as a replacement for simple serial did not work, maybe just a setup issue but does full duplex serial support communication on one pin at all ?
Is there a problem with the Position Controllers or my code ?
Any ideas ?
CON
' Global constants required, can be removed from here
  _clkmode = xtal1 + pll16x
  _xinfreq = 6_250_000
  MPC_Pin       = 25
  QPOS                          = $08                   'Query Position
  QSPD                          = $10                   'Query Speed
  CHFA                          = $18                   'Check for Arrival
  TRVL                          = $20                   'Travel Number of Positions
  CLRP                          = $28                   'Clear Position
  SREV                          = $30                   'Set Orientation as Reversed
  STXD                          = $38                   'Set TX Delay
  SMAX                          = $40                   'Set Speed Maximum
  SSRR                          = $48                   'Set Speed Ramp Rate
  PING_Pin1 = 0                                          ' I/O Pin For PING)))
  PING_Pin2 = 1                                          ' I/O Pin For PING)))
OBJ
  PosCtrl       : "simple_serial"
VAR
  word wheel_pos1
  word wheel_pos2
  word wheel_speed1
  word wheel_speed2
  word pingCenter1
  word pingCenter2
  word pingRight1
  word pingRight2
  word pingLeft1
  word pingLeft2
  Long SensorStack[300]
PUB start | x , y
  cognew(SensorsUpdate,@SensorStack)
PRI getWheelPosition
    PosCtrl.tx(QPOS+1)
    PosCtrl.tx(QPOS+2)
    wheel_pos2.BYTE[1] := PosCtrl.rx
    wheel_pos2.BYTE[0] := PosCtrl.rx
PRI getWheelSpeed
    PosCtrl.tx(QSPD+1)
    wheel_speed1.BYTE[1] := PosCtrl.rx
    wheel_speed1.BYTE[0] := PosCtrl.rx
    PosCtrl.tx(QSPD+2)
    wheel_speed2.BYTE[1] := PosCtrl.rx
    wheel_speed2.BYTE[0] := PosCtrl.rx
PRI ClearPos
      PosCtrl.tx(CLRP)
PRI SensorsUpdate
  PingServo.Start                 'Start Servo handler
  PingServo.Ramp  '<-OPTIONAL     'Start Background Ramping
  PingServo.set(PingServoCh1, 1500)
  PingServo.set(PingServoCh2, 1500)
  PosCtrl.init(MPC_Pin,MPC_Pin, 19200)                   ' Establish comunications to MPC
  ClearPos
  PosCtrl.tx(SREV+2)
  PosCtrl.tx(STXD)
  PosCtrl.tx(200)
   repeat
     readPingCenter
     getWheelSpeed
     getWheelPosition
PRI readPingCenter
    pingCenter1 := ping.Millimeters(PING_Pin1)
    pingCenter2 := ping.Millimeters(PING_Pin2)
PRI readPingLeft
    pingLeft1 := ping.Millimeters(PING_Pin1)
    pingLeft2 := ping.Millimeters(PING_Pin2)
PRI readPingRight
    pingRight1 := ping.Millimeters(PING_Pin1)
    pingRight2 := ping.Millimeters(PING_Pin2)
  • Tom CTom C Posts: 461
    edited 2011-08-29 10:05
    Bamse,
    You might want to have a look at the attached code as an example.
    TCIII
  • BamseBamse Posts: 561
    edited 2011-08-29 17:56
    Howdy...
    Wheel_Controller.spin does not seem to work either...
    The speed/position returned is always zero...
    Anyone used this driver ?
    OBJ
      PosControl    : "Wheel_Controller.spin"
        wheel_pos1 := PosControl.get_Wheel_Position(PosControl#LEFT_WHEEL)
        wheel_pos2 := PosControl.get_Wheel_Position(PosControl#RIGHT_WHEEL)
    PRI getWheelSpeed
        wheel_speed1 := PosControl.get_Speed(PosControl#LEFT_WHEEL)
        wheel_speed2 := PosControl.get_Speed(PosControl#RIGHT_WHEEL)
    PRI SensorsUpdate
      PosControl.open(MPC_Pin)
       repeat
         ''readPingCenter
         getWheelSpeed
         getWheelPosition
    edited 2011-08-31 23:14
    So it seems like the Position controllers gotten the best of me...
    Simple serial seem to sooner or later get stuck in one of the rx calls.
    Wheel_Controller.spin always return 0 for speed and position...
    If I hook the HB25 to the position controllers and try for example go_Distance, the robot goes amok and runs off.
    Actually, I just have to give one of the wheels a little bit of a turn and is starts spinning out of control, the only thing I did was to call PosControl.open(MPC_Pin).
    If I use FullDuplex I always get 204 returned (speed and pos) and it seem to always time out.
    Anyhow, I'm thinking about by-passing the micro controller on the position controller and just solder wires from the actual opto interrupter...
    Anyone done this ?
    edited 2011-09-01 04:18
    Bamse,
    Since your wheel starts to spin out of control when given a little bit of a turn, it might just be that you are driving the wheel in the opposite direction that the position controller is programmed for?
    Just a thought.
    TCIII
    Howdy...
    I'm not really interested in using the Wheel_Controller object so I dropped the idea.
    All I really want is the speed and distance from the encoders.
    I actually want to write my own Wheel Controller object that only uses the speed and distance feedback from the wheel encoders.
    If I can get this to work, I can migrate the code to another project...
    I thought of one thing yesterday, I'm using a 6.25 MHz crystal to run the propeller @ 100 MHz.
    Let me try a 5MHz crystal from one of the proto boards to see if it is more stable.
    I'll be out of town until next week though so I won't be able to test this for a while.
