How about a digital speedomoter display for my bracket corvette
Hey guys its been a while I have been busy long story short I drag a 1982 corvette the speedometer used to work but that was before I fixed it,lol I shopped around for ready made stuff very expensive and my vette has a mechanical cable I was wondering since I have so many prop boards hydras could someone think of a way that maybe I could use the tach output off the magneto and calibrate it that way? I do drive this on the street sometimes and believe it or not going slower than the posted speed limit will get you pulled over faster than speeding they think you have something to hide then they start with the pipes the roll cage the nitrous bottles all the bs I can not just replace the old speed dash becuase I cut it up to add my auto tach with shift light trust me there is no room in a vette so I have to use in dash you can not let stuff obstruck view in 9 second class and guess who gets to decide your view!
anyway one other thought was to buy a GPS unit with speed display and build it into dash but the numbers are pretty small I have a ton of display for prop boards that would look awesome in dash Oh this is a carb no computer straight up bracket 10.5 so no can or odb to pull signals off of thanks guys
I just saw some cool ones at the track the guys did not use prop chips prob
pics but no one will tell thier secrets
P.S. Just wondering what type of motor are you running.
One problem I just thought of is that using the tach signal you would have to know what gear you are in.
That way it would remain balanced.
Duane
Nope that won't work. There are too many factors. Firstly, you have different gears in the transmission that vary the output. Secondly, monitoring the driveshaft won't work either, becuase you also have gearing in the rear end. In most cases, or at least this is how it was done in the past, the speedo gear that goes into the trans matches the output on the gear ratio of the rear differential, plus I would assume tire size was accounted for.
On the other hand, if you know the actual gear ratio of the differential, then you could monitor the drive shaft and apply the ratio to your arithmetic, but you must also compensate for the diameter or circumference of your tires to obtain MPH.
You could monitor you MPH electronically with a hall effect on your wheel to measure RPM, and then apply the math for the diameter or circumference of your tires to obtain MPH.
Bruce
This guy shows how he did that on his Jag; it's all the same, a thousand variations on a theme.
Hope this get Propellery soon.
That looks pretty cool and they claim:
Or paint one side white and one side black and use an optical sensor? The paint is guaranteed not to throw the shaft off the balance (and can't come loose at high speed
Oh and with two optical sensors it can tell you if you are reversing or not!
The only problem with that is that the drive shaft is exposed to a very dirty environment so the optical sensor and paint marks would eventually be covered. Simpler to use a speedometer cable and put the sensor in the cabin.
He must have been joking, hence the smiley.
Bruce
