NES Gamepad Controller Adapter
If have bought a NES Gamepad Controller Adapter, from the parallax store.
I have sometimes the following problem, not everytime:
When i press the 'b' button it will not be showed through the terminal.
When i press the 'a' button the red led begins to flicker, the terminal program showed i have pressed the 'b' key !
CLK - P4
LATCH - P5
DATA1 - P6
DATA2 - P7
+5V - 5V
GND - GND
CLK - P4
LATCH - P5
DATA1 - P6
DATA2 - P7
+5V - 5V
GND - GND
Could you post your code?
OBC
http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/32368-NesGamepadCtrlrAdapter-v1.0.pdf
On page 2 you can read: CLK - P4, LATCH - P5
On page 5 you can read: CLK - P5, LATCH - P4
I get only results when i used the first combination with the code on page 5 !
Most NES interfacing is based on the original Propeller NES design, The Hydra.
P3 NES CLK ‘clock’
P4 NES SH/LD ‘latch’
P5 NES A OUT ‘data’
3.3v Power
Gnd Ground
OBC
