Help pls: Newbie question on Say It Module
Hi all,
I have a very basic problem with Say it:
I don't have any problem setting the words on GUI Software. Also I can generate the code without problems.
The trouble appears when I run the generated code on Stamp Editor environment, because after the download process (F9) it appears on the PC screen the communication windows with the follow message:
Setting up VRbot...awake...lenguage 0....time out 5
VRbot ready!
VRbot in group 0 wating for command....timed out
and so on...
From the beggining of the program the red LED of Say It Module is off, and no matter I try with the trigger word(s) or any other word from the Groups 1 to N, the same message continue on screen.
I am using a Basic Stamp Super Carrier with the say it module inserted on the right socket and the Stamp is a BS2px24
Do you know what I am doing wrong?
Do you have any advice to avoid this problem?
Thanks in advance, regards
daniel
VRbot ready!
and so on...
daniel
Dave
I tried to change the baudrate without success, so I changed the PIC, I placed a BS2 and now the module appears to recognize the Trigger command.
But...I can't go further, I can link the recognition of the trigger with the recog process of some of the SD commands I have setup and trained. The program retunrs to the Trigger recog and never go further.
I think I can't understand totally the code, so if you can give some I will really appreciatte your post.
Thanks and regards
daniel
(I hope I attached the code here)
Regards
daniel
