Mcp2200 — Parallax Forums
Mcp2200
lfw94lfw94 Posts: 5
edited 2011-08-29 00:33 in BASIC Stamp
Hey guys
I have a little problem.
I use the mcp2200 Uart to USB converter.
I don’t now how I make a loopback.
Can someone say me how I must connect the pins?
Where must the RTS and CTS at the Basic Stamp Chip be?
Sorry for me English I’m from Switzerland.
Datasheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/22228A.pdf
  • stamptrolstamptrol Posts: 1,731
    edited 2011-08-24 05:15
    Welcome to the Forums.
    Typically, loopback refers to connecting Rx and Tx together to check the functioning of the communication link.
    There may be a problem with the mcp2200 and programming the Stamp as the Stamp needs the DTR signal to operate at the end of a program download to tell the Stamp to reset. In your datasheet, I don't see the DTR or DTS signal.
    The FTDI chips are known to work with the Stamps and are discussed on the Parallax Store website.
    Cheers,
  • lfw94lfw94 Posts: 5
    edited 2011-08-28 23:09
    thank you
    but I want to use the mcp2200
    Not sure about the mcp2200, but some USB adapters give inverted signals and can work once an inverter is added. See http://forums.parallax.com/showthread.php?133195-USB-Adapter-Fix
