Default command to Reset Stamp while immediately interrupting execution?
When using the debugging window on BASIC Stamp Editor, is there a key-stroke or key-stroke -combination that can be entered to Reset my Boe-Bots BS2 (as if I were to press the Reset button physically)? In essence, I need an emergency exit/stop then reset command to interrupt whatever it is the Boe-Bot is executing, even a loop. I know I myself could create this control, and it is not advised to interrupt any execution before it has finished; I just want to know if there is a stock/standard key-stroke or key-stroke combination that will Reset the robot.
