Screen formatting with Parallax Serial Terminal — Parallax Forums
Don MDon M Posts: 1,654
edited 2011-08-19 13:20 in Propeller 1
Lets say I have 2 messages to print on the terminal screen. I would use:
term.str(string("This message 1 here"))
term.str(string("This message 2 there"))
How do I send the "cursor XY" command to PST so that I can have message 1 in a specific location and message 2 in its specific location?
I know that the CRSRXY command to PST is 2 but I can't figure out how to send 2,0,2 (first line 2nd column) for message 1 and 2,4,2 (fifth line 2nd column) for message 2.
I tried: term.tx(2,0,2) and term.str(2,0,2) but they won't compile.
Help!
Thanks.
Don
Edit: I don't want to use the ParallaxSerialTerminal object if I don't have to. I am using FullDuplexSerialPlus object.
  • Don MDon M Posts: 1,654
    edited 2011-08-19 10:48
    I figured it out-
    term.str(string(2, 1, 5, "Message here"))
    I can enter it prior to the message.
    edited 2011-08-19 11:02
    Right. The only catch is that you can't send a zero that way. For that, you will have to use tx.
    Addendum: You can also use the PST object's Position method to do what you want.
  • JonnyMacJonnyMac Posts: 9,839
    I use this method in a lot of my test programs that have PST output:
    pub moveto(x, y)
    '' Move cursor for PST
      term.tx(GOTOXY)
      term.tx(x)
      term.tx(y)
    At the top of my programming template I have the following PST declarations:
    con
       #1, HOME, GOTOXY, #8, BKSP, TAB, LF, CLREOL, CLRDN, CR       ' PST formmatting control
      #14, GOTOX, GOTOY, CLS
    There are others but these are the commands I routinely use.
