Complicated Serin-Serout
Serial communication is the hardest thing on the BS2!
I am communicating with a lighting controller and everything works through Hyper Terminal . With HT, I send the following with carriage return:
chan int:128 c1 (set the intensity of channel c1 to 128 or 50%)
The controller then responds with
chan c1 int:128
using 16468 as equivalent to the setting in HT of 9600, no parity, 1 stop bit (8 data bits is mandatory) (I also tried 84 without any luck), I send the following from the BS2:
p_lightsTX PIN 15
p_lightsRX PIN 11
c_lightsBaud CON 16468 ' Baud set at 9600
inText VAR Word
SEROUT p_lightsTX, c_lightsBaud, ["chan int:0 KP 5",CR]
SERIN p_lightsRX, c_lightsBaud, [inText]
DEBUG HOME, inText
I get nothing but garbage in the debug window and the commands have no effect on the controller. The system obviously works from HT. How can I make it work from BS2?
Please help,
Al
chan c1 int:128
p_lightsTX PIN 15
p_lightsRX PIN 11
inText VAR Word
DEBUG HOME, inText
Please help,
Al
(I ask because you give the one example from/for HT and another, chan int:0 KP 5, for the Stamp.)
So far as the confirmation / reply back to the Stamp, from the controller, inText and SERIN must be configured as an array (of bytes). You could probably shorten that up with a WAIT
1. Are you sure the lighting controller can work with serial voltage levels of 0 volts and 5 volts as generated by the Stamp pin? If the controller is expecting 'real' rs-232 voltage levels, you may have to add a level shifting chip. Or, use the programming port (pin 16). The baudrate number will go to 84. I'd get the SEROUT part working before worrying about the SERIN part.
2. Because the Stamp has no communication buffer, your SERIN has to be executing when the data arrives. Usually you can use the 'WAIT' modifier to get the program to wait for a specified character before executing.
what is the best way of adding a "level shifting chip"? is that something off the shelf on a separate circuit board that I can plug into or do I have to redo my circuitry?
thanks,
Al
Several level shifter chips are available. I like the MAX233 as no external capacitors are required, but the MAX232 and ST232 work fine as well.
Cheers,
many thanks again,
Al
It will depend on the type of cable (twisted, coax, parallel ,shielded or not) and the speed. I've run 300 feet at 9600 to drive a remote display at standard +/- 12 volt rs232 levels.
Cheers,
