You'll be wasting a lot of energy by connecting all 30 in parallel, and each would need its own current-limiting resistor. I would recommend creating multiple strings of, say, four LEDs in series, each of which will include a series resistor to limit current.
That might work... although I may have to make a few adjustments to the layout. What resistance would you recomend for the multiple strings of four LEDs in series?
If this is a 9-volt "transistor" (as in old style radio) battery it's not going to last very long running 30 LEDs. Even if you cut down the current draw to each LED to 5-10 mA, that poor old battery is going to run out of juice in no time.
The way they usually do this is to multiplex the LEDs, and strobe them one (or smaller groups of 3-5) at a time. They look like they're all on at the same time because of persistence of vision.
A microcontroller would do this, but so could a 555 and 4017 counter chip. You'd probably also want a driver like the ULN2003, because I don't think the 4017 can drive more than a couple LEDs on each pin.
All of a sudden this is a lot more complicated than it started out as!
The forward voltage of that LED is probably around 1.7V. So 4 x 1.7V = 6.8V. To limit your current to 10 mA, say, with a full 9V source, you would need a (9 - 6.8) / 0.010 = 220 ohm resistor in series with each string. As Gordon suggests, though, your battery will not last very long.
With your 12V supply, you could put six LEDs in a string. I'll let you calculate the series resistor this time, since I've shown you how to do it.
according to my calculations, I will need a 10.4 ohm resistor in sereies with strings of four LEDs with the 12V 500mA power supply. Is that correct?
It seemed like such an odd number.
No, I'm afraid that's not even close. And, with 12V you should use five or six in a string, not four, to save power. How did you come up with your answer?
Oh. You definitely don't want to run 500 mA through your LEDs! The 500 mA spec is how much the supply can source if you need it, but you don't anywhere near that much here. Try the computation with somewhere between 10 mA and 20 mA. Also, is your supply regulated or just a wall wart? If the latter, be sure to measure the actual voltage with no load, since it will probably be a lot more than 12V.
The "safe side" of LEDs is a lower current. With too high of a current the LEDs will start to lose their color and produce a more whitish output and with way too much current the LEDs will pop and die. Most LEDs will be lit even with very low current, and you can always work your way up to a higher current if you need more brightness.
-- Gordon
'How low can you go'?
Take into consideration the ambient light where they're being placed, the surface around them and all that.
You may be able to go below 10mA if it'd a 'dark and dank' situation.
