Just a little POST/GET FYI ... — Parallax Forums
Beau SchwabeBeau Schwabe Posts: 6,575
edited 2011-08-17 17:22 in Accessories
Perhaps this is old news to some of you, but it hung me up last weekend...
When you post or get data i.e. ....
http://{Some valid IP address}:{Some valid Port Number}/{text}
... some characters in the 'text' can cause problems. for example a # (pound sign) if you send something like...
http://192.168.0.1:3333/This is a test
... it will come through just fine, however if you send something like ...
http://192.168.0.1:3333/This is test #5
... the # plus anything to the right of it will truncate, so on the receiving end all you see is...
This%20is%20test%20
... Anyway, just an FYI I thought I would share, and my own suspicion why I'm having similar issues with 'Smart Phone' data submissions. I'll setup a test page this weekend to show you an example.
    edited 2011-08-16 13:59
    Beau,
    Can't you just send %23 for the "#"?
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2011-08-16 14:02
    You could, but this was for a form field that would be submitted, in which case, there would need to be a check to make the conversion prior to submission.
    edited 2011-08-16 14:13
    That's strange. # is considered a reserved character in a URI, so your browser should convert it to %23 automatically when submitting the form.
    edited 2011-08-16 14:17
    "That's strange. # is considered a reserved character in a URI, so your browser should convert it to %23 automatically" - One would think, but I've come to realize that you can't assume anything, especially when trying to make something that is cross browser compatible (<- I won't mention any names here) ... just an FYI
  • Mike GMike G Posts: 2,702
    edited 2011-08-16 15:16
    In the URL, the # is used as a named anchor. As Phil stated the # has to be URL encoded if you want to use the # for some other purpose, otherwise it needs to be at the end of the URL for the named anchor to function as expected. In a POST the # has to be HTML encoded, so you might try adding the enctype attribute in the form tag.
    enctype="application/x-www-form-urlencoded"
    However, application/x-www-form-urlencoded should be the default. You need the method="post", method="get" uses the URL to pass state data. If all else fails there is always JavaScript onsubmit.
    HTML
    <form action="post.htm" method="post">
                <div class="content">
                    <h2>Submit</h2>
                    <label for="name">Name:</label>
                    <input type="text" name="name" />
                    <input type="submit" name="submit" value="Submit" />
                    <div id="placeholder"></div>
                </div>
            </form>
    FireFox
    POST /post.htm HTTP/1.1
    Host: spinneret2:5000
    User-Agent: Mozilla/5.0 (Windows NT 5.1; rv:5.0) Gecko/20100101 Firefox/5.0
    Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
    Accept-Language: en-us,en;q=0.5
    Accept-Encoding: gzip, deflate
    Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
    Connection: keep-alive
    Referer: http://spinneret2:5000/post.htm
    Content-Type: application/x-www-form-urlencoded
    Content-Length: 37
    name=This+is+a+%23+test&submit=Submit
    IE
    Accept: image/gif, image/jpeg, image/pjpeg, image/pjpeg, application/xaml+xml, application/vnd.ms-xpsdocument, application/x-ms-xbap, application/x-ms-application, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, application/x-shockwave-flash, */*
    User-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; chromeframe/13.0.782.112; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; OfficeLiveConnector.1.3; OfficeLivePatch.0.0; .NET4.0C; .NET4.0E)
    Content-Length: 37
    Connection: Keep-Alive
    Cache-Control: no-cache
    edited 2011-08-17 06:31
    Here's a JavaScript example that encodes the value of a textbox in a web form.
    <html>
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title>POSTing to the Server</title>
    <script language="javascript" type="application/javascript">
    	function htmlEncode(target)
    		var tag = document.getElementById(target);
    		var str = escape(tag.value);
    		tag.value = str;
    		return true;
    </script>
    </head><body>
    <div style="width:600px;margin:auto;">
        <form id="post" name="post" method="get">
            <input id="led" type="text" name="led" />
            <input type="submit" name="Submit" onClick="return htmlEncode('led')" value="Click Me!" />
        </form>
    </div>
    </body>
    Here is an example of the # problem I was describing using a similar fix with the JavaScript 'replace' command...
    DataToSend = DataToSend.replace(/#/g,"%23");
    The code below would normally live on a traditional server and send data to a custom server such as the Spinneret.
    <!doctype html>
    <meta http-equiv='X-UA-Compatible' content='IE=EmulateIE7' >    <!-- Emulate Internet Explorer version 7 compatibility -->
    <head>
    <script LANGUAGE='JavaScript'>
            function FormSubmit(form) {
                     var PageID = "[Parallax Test]";   		  // Create an ID, so the server knows the data source //
                     var DataToSend  = PageID          		  // Initialized Data to Send                          //
                         DataToSend += "["+form.Comment.value+"]";    // append Data to send                               //
                     form.Comment.value = "";                         // Clear field, so that when the server returns us   //
        // the next person in line does not see the data.    //
                     DataToSend = DataToSend.replace(/#/g,"%23");	  // replace all # signs with %23                      //
                     WindowID = window.open("http://24.253.241.231:8890/"+DataToSend,"_self","");   // Send data to server //
    </script>
    </head><body>
           <P align=center>
              <input type="button" name="Submit" onClick="FormSubmit(this.form);" value="Click Me!" />
               Please leave your comments in the box below.<br>
               <textarea rows=10 cols=60 id=Comment name='Comment'></textarea>
            </P>
        </form>
    </div>
    </body>
