BS2 Communication Code Help
I have a working model using an encoder chip for a keypad door entry program. I am building a second one but if possible would like to use a keypad remaining from a commercial system. Here is the information on it:
It uses Special ABA Data Format as follows:
All characters are sent as a 5 bit value.
First 4 bits of each character are the data value LSB first
The last bit of each character is odd parity
First 13 0's are sent as lead in
Next the Start Character is sent
The start character is a "B" with odd parity bit
Each entered character is now sent as 5 bits per character with odd parity and LSB first. Max. of 12 characters
After all the keyed in characters have been sent, then the END Sentinal is sent which is an "F" with odd parity
Next the LRC code is sent as a 5 bit character with odd parity. The LRC code is created by XORing all of the characters sent including the Start Characters the Digit Characters and the End Sentinal. It is calculated as a 4 bit value from XORing all the previous characters. Its value is then sent as a 5 bit value, the 5th bit beign its own odd parity.
Finally 7 0 bits are sent as lead out.
Clock pulse is 200 uSec
Interbit delay is 750 uSec
This information was given to me by the Mfg. Given this, is it possible to use this with the BS2?
Thank you,
Daniel
Thank you,
Daniel
Thank you for your reply. I did contact the Mfg. and what I wrote above is exactly what they sent me concerning the data specifications. This was a special model so their website did not cover it.
They sent some I/O specifications also as follows:
Input 1 <Low>= Green LED On <High>= Green LED off
Input 2 <Low>= Red LED On <High>= Red LED off
Input 3 NONE
Input 4 <Low>= Invert Data <High>= Normal Data
Output 1 <Clock> Goes low to clock in data
Output 2 <Data> Output determined by Input 4
Input 3 <Low> 0=Low & 1=High (inv)
Input 3 ,High> 0=High & 1=Low (nor)
Output 3 NONE
Output 4 <CCTV> with 30 sec timer goes low for CCTV on
Clock Pulse is 200 uSec
The Red LED blinks with each key press
Tone is output with each keypress
---Key Specifications----
* is the Enter Key
# is the Clear Key
The clear delay is set at 10 seconds
If over 12 data keys are pressed before enter, there is no output from the keypad.
---Purpose----
Drive Essex internal keypad micro as a Multi Bit ABA Type Clock and Data keypad
Special version # and * keys reversed
Outputs on only enter, 9 extra leada 0's
http://www.keyless.com/tech.htm This is the website, but the keypads I have are special versions of their KTP line.
Above herein and my first post are exactly what the Mfg. sent me when I asked them about the communications protocol for the keypad I have.
You must be correct that it is hexadecimal because they do state it is 5 bits.
I have a homework board set up for testing, the final version will be a BS2pe Module.
I will research and refresh my memory on the SHIFTIN command.
Thank you,
Daniel
Blue wire = Red LED
Black wire = earth ground -(was not used previously)
Gray wire = CCTV (was not used previously)
Brown wire = Green LED
Yellow wire = -V
Violet wire = IN4 (was not used previously)
Orange wire = +V
Green wire = Data
Red wire = Clock/Strobe
Thank you,
Daniel
Thank you.
Daniel
Thank you for the great help. Since the homework board may not work I'm getting my carrier board set up.... work meeting tomorrow so hopefully I'll make some more progress on Friday. Thank you very much! I am a hobbyist.. and this is something I rarely deal with so takes a while to get my mind focused and on the right path on this stuff.
Daniel
In the example I gave, I didn't check that the clock went high again before looking for it to go low. I assumed that the code would take at least 200us to execute, so the clock would go high when the Stamp was looking at the data line. That may not work with the BS2pe because it's faster.
I got the 2p3 up and running and was doing some testing with your first code. I don't think from your last code that I have it set up right... if I run it it with the following code it just displays "END" should I add something to look for the clock to go low since I am using the 2pe? I will try to make some corrections after reading your link and new code and see if I can make some progress. Thank you... Daniel
' {$STAMP BS2pe}
' {$PBASIC 2.5}
'test program to read from Essex keypad
CLK PIN 3 ' keypad strobe pin
DTA PIN 4 'keypad data pin
counter VAR Byte
dataValue VAR Word
counter = 0
dataValue = 0
DEBUG CLS , CR
error: ' start over from beginning
DO UNTIL CLK = 1 : LOOP 'make sure clock is high initially
section1:
DO UNTIL CLK = 0 : LOOP ' wait for leading edge of clock pulse
IF DTA <> 0 THEN GOTO error 'quit if leading bit is in error
counter = counter + 1 'require 13 leading bits
IF counter < 13 THEN GOTO section1
counter = 0
dataValue = 0
section2:
dataValue.BIT0(counter)= DTA 'get data bit from LSB to MSB
IF counter < 6 THEN GOTO section2
DEBUG dataValue.BIT0(counter), CR
DEBUG "END", CR
END
I am either not catching the data input or don't understand how to properly write the code to display it yet.
Thank you,
Daniel
If I enter 3 or less numbers and then press star I have to do a second entry before the counter is up high enough to end the program. If I enter 4 numbers and then press star it displays 0 for result and 21 for counter. If I raise the counter number it does not always reach the END entering four numbers... If I lower it enough it will reach the end entering 3 numbers. My final code would be trying to read 4 numbers.
counter VAR Byte
result VAR Word
DEBUG "start", CR
section2:
result.BIT0(counter)= DTA 'get data bit from LSB to MSB
IF counter < 21 THEN GOTO section2
DEBUG ?result
DEBUG ?counter
DEBUG "END", CR
END
1) The BS2 is a fairly slow processor. Its basic instructions execute only slightly faster than the clock you're getting from the keypad and there's very little the BS2 can do up until the next bit (and clock) comes in. Storing the data in a buffer of some sort is even slower since you have to do subscripting and keep a counter, etc.
2) There's limited space available in the BS2 (only 26 bytes) for a buffer and you have to keep some bytes for use as counters or other variables in your program.
The "unrolled" code technique is an attempt to speed things up as much as possible and to use only a few variables.
Coding would be easier using a more capable Stamp like the BS2px or a much faster, but different microcontroller like the Propeller. I made the coding suggestion because you might get the task done with a BS2 and really careful coding.
Regarding your message #11 ... You're probably missing some bits. It would be interesting to look at what you do have as bits (use DEBUG BIN16 result to see the bits) to see if there's a pattern
I tried this
DEBUG BIN16 ?DTA
DEBUG ?result
DEBUG ?counter
DEBUG "END", CR
and got this :
start
DTA = %0000000000000000
repeats 0's several times.. then after enough entries the program ends.
I don't seem to be catching anything.. do I have it coded right to read the data from pin 4? Clock is on pin 3.
Thank you.
As I mentioned before, this scheme is not likely to work with a BS2 and the serial timings you've described. That's why I posted the "unrolled" loop code in #5 which avoids the additional overhead of the subscripting and keeping a counter.
Is the problem that the timing has to be just right to catch the bchar at the correct time?
Is it possible to use the unrolled code and catch bits until the clock goes to 0 and then display what I am catching? At some point here I should be able to catch something other than one of the leading 0's shouldn't I?
Thankful for the help.
Daniel
Given your project description (a keypad-based entry system), you'd probably be better off removing the electronics from the existing keypad, making direct connections to the (probably) 4x4 keyboard, and scanning the keyboard directly with the Stamp using sample code readily available (and tested).
Thank you again for your suggestions, it was worth a try.
Daniel
