Code doesn't want to configure for ViewPort
@ Any one,
For some reason this code seems to run OK, but I cannot get ViewPort ver 4.5.3 to configure properly. I've tried the '4-bit counter' on the board and that runs OK, but not this. I'm trying to use the Logic Analyzer mode to view some timing relationships.
Ths 'ViewPort portion of the code' was copied/pasted and modified from a program that runs OK. But not this. Probably some stupid error on my part, but I just cannot see what's not right.
'' File....... LCD_24x1.spin
'' Purpose.... to bring-up a 24x1 LCD (All Elect. LED-111 a Wintek# WDC2401P-1GNNA)
'' Author..... Harley Shanko - used Jonny Mac's QuickStart demo with mods
'' Copyright (c) 2011 H Shanko
'' -- see below for terms of use
'' E-mail..... hshanko@OregonsBest.com or HarleyShanko@gmail.com
'' Started.... 31 Jul 2011, 11:04 am; used Jonny Mac's source to begin
'' Updated.... 15 Aug.2011 3:31 pm
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000 ' QuickStart board uses 5MHz crystal
' _xinfreq = 6_250_000 ' use 6.25MHz crystal
CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq
MS_001 = 80_000_000 / 1_000
' MS_001 = CLK_FREQ / 1_000
' US_001 = CLK_FREQ / 1_000_000
' Prop 1 I/O usage (P31..P0)
RX1 = 31
TX1 = 30
SDA = 29
SCL = 28
{{ unused
= 27
= 26
= 25
= 24 }}
LED7 = 23
LED6 = 22
LED5 = 21
LED4 = 20
LED3 = 19
LED2 = 18
LED1 = 17
LED0 = 16
{{ TV video and audio use
= 15 ' audio use
= 14 ' video lsb
= 13 ' " 2nd lsb
= 12 ' " msb }}
E_LCD = 11 ' HI = Load, on negative edge Latch
RW_LCD = 10 ' LO = Write, HI = Read
RS_LCD = 9 ' LO = Command, HI = Data
reset_LCD = 8 ' LO = Reset, HI = reset released
PAD7 = 7
PAD6 = 6
PAD5 = 5
PAD4 = 4
PAD3 = 3
PAD2 = 2
PAD1 = 1
PAD0 = 0
#1, HOME, GOTOXY ' PST formmatting control
#8, BKSP, TAB, LF, CLREOL, CLRDN, CR, GOTOX, GOTOY, CLS
VAR
long stack[50], frame[400], cntDn
byte chr
OBJ
' term : "fullduplexserial" ' = FDS
' TV : "TV_text" ' to be used later, maybe
vp : "Conduit" ' transfers data to/from a PC; uses 1 cog
qs : "QuickSample" ' captures INA, variables; uses 1 cog, samples at 20 MHz
' dbg : "PASDebug" ' Include for PASD Debugger (MUST include binary file)
PUB Main ' Cog 0
vp.register(qs.sampleINA(@frame,1)) 'sample INA w/ 1 cog up to 20 MHz (MUST BE COG 0)
optional_configure_viewport ' optionally configure Viewport's interface
vp.share(@cntDn,@chr) 'share memory from 'cntDn' to 'chr'; END of VP commands <<===
' Display.start(12) ' " Cog 3
' id := cognew(@DTbus,@DTarray[0]) ' this sets up the DTbus registers for the DTbus cog
' id := cognew(@entry,@DTarray[0]) ' cog for DTbus R/Ws; Cog 3; PASD; CmdStatus=>StatAsm @ PAR
' id := dbg.start(31,30,@entry) ' Include for PASD debugger (NOTE: PASD needs a 'xxx.bin' file)
{{ term.start(RX1, TX1, %0000, 115_200) ' init FDS
term.str(string(CLS, "QuickStart LCD test, 15 Aug.2011"))
waitcnt((MS_001 * 1000 +cnt)) }}
initLCD
dira[LED7..LED0]~~ ' LEDs are outputs from Prop
' DIRA[E_LCD..PAD0]~~ ' make P0..P11 outputs on Prop (this just a TEMP use)
cntDn := 0
repeat
if cntDn == 0 ' check if value reached zero
cntDn := $0000_0FFF ' if so, set to FFFh
outa[LED7..LED0] := cntDn ' output cntDn value to LEDs
OUTA[PAD7..PAD0] := $0000_00FF & cntDn ' output also to LCD's 8 lines
chr := $00FF & cntDn
wr_LCD
{{ term.tx(HOME)
term.hex(cntDn, 4)
term.tx(CR) }}
cntDn := cntDn - 1 ' decrement value
waitcnt((MS_001 * 1000) +cnt) ' pause to display for human eyes; ~45 ms loop time by scope
PUB optional_configure_viewport ' FROM CONTROL1
vp.config(string("var:io(bits=[all[0..29],30tx,31rx])"))
vp.config(string("var:io,cntDn,chr")) ' show these VARs
vp.config(string("lsa:view=io,timescale=200ns,trigger=io[23]r")) ' trig on A23 rising
vp.config(string("edit:chr(default=5,mode=text),cntDn(mode=text)"))
vp.config(string("start:lsa"))
PUB initLCD
{{ term.tx(CR) }}
OUTA[E_LCD..reset_LCD] := $1<<8 ' set E_LCD..reset_LCD (LCD control lines) LO
waitcnt(MS_001*2100+ cnt) ' delay about 20 ms
' OUTA[reset_LCD]~ ' release reset line
' waitcnt(MS_001*10 + cnt)
chr := $1C ' turn on LCD driver power
wr_LCD ' send command
chr := $14 ' turn on character display
wr_LCD
chr := $28 ' set for '2 by 12 char. lines'
wr_LCD
chr := $4F ' set at darkest contrast
wr_LCD
chr := $E0 ' set data address to first location
wr_LCD
OUTA[RS_LCD]~~ ' set RS line Hi for Data transfer
waitcnt(MS_001*100 + cnt)
{{ term.str(string(CLS, "initLCD done"))
term.tx(CR) }}
PUB wr_LCD ' enter with RS Hi for Data, LO for Commands
OUTA[E_LCD]~~ ' E line Hi to load value
' waitcnt(MS_001 + cnt)
OUTA[PAD7..PAD0] := chr ' byte to LCD for Data/Command
OUTA[E_LCD]~ ' drop E line to latch the value
{{ term.tx(HOME) ' TEMP USE, this, next5 lines
term.str(string("wr_LCD = "))
term.hex(chr, 2)
term.tx(CR) }}
waitcnt(MS_001 * 10+ cnt) ' wait for about 1 millisecond ' 10 ms enough ???
dat
It works for me, though I think timescale=200ns is a little quick for the other pins which are slower transitions.
I sent you note, please check you're inbox.
Hope to get the install done today and give it a try. Would love to see VP working on this QS board. Yes, I may not have the timing optimum; since VP hadn't worked yet I didn't even attempt to set a better default timescale. I noticed that but it didn't matter yet. Have some non-Prop things to handle before getting back to the debugging part today/tomorrow. Ah, yes, there is always Ma
what do you see when running viewport with acode that you call "OK" and what do you see when running code that you call "not working"?
I tested your code with ViewPort 4.5.3. First it did run. Now it doesn't anymore and I have a message "wait for trigger" in the lsa-view.
What does this mean and how can it be made triggering all the time?
best regards
Stefan
I tried your code with Version 4.5.1 and 4.60. You will not get any change on the LSA , (not triggered), with your code triggering on PIN23 (LED7), as it never changes.
I changed the trigger pin to P16 and set the time scale to 10us, and it seems to work fine.
These tests were done on a Demo Board, as I don't have a Quick Start, (yet).
''=========================================================================================== '' '' File....... LCD_24x1.spin '' Purpose.... to bring-up a 24x1 LCD (All Elect. LED-111 a Wintek# WDC2401P-1GNNA) '' Author..... Harley Shanko - used Jonny Mac's QuickStart demo with mods '' Copyright (c) 2011 H Shanko '' -- see below for terms of use '' E-mail..... hshanko@OregonsBest.com or HarleyShanko@gmail.com '' Started.... 31 Jul 2011, 11:04 am; used Jonny Mac's source to begin '' Updated.... 15 Aug.2011 3:31 pm '' '' =========================================================================================== CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 ' QuickStart board uses 5MHz crystal ' _xinfreq = 6_250_000 ' use 6.25MHz crystal CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq MS_001 = 80_000_000 / 1_000 ' MS_001 = CLK_FREQ / 1_000 ' US_001 = CLK_FREQ / 1_000_000 ' Prop 1 I/O usage (P31..P0) RX1 = 31 TX1 = 30 SDA = 29 SCL = 28 {{ unused = 27 = 26 = 25 = 24 }} LED7 = 23 LED6 = 22 LED5 = 21 LED4 = 20 LED3 = 19 LED2 = 18 LED1 = 17 LED0 = 16 {{ TV video and audio use = 15 ' audio use = 14 ' video lsb = 13 ' " 2nd lsb = 12 ' " msb }} E_LCD = 11 ' HI = Load, on negative edge Latch RW_LCD = 10 ' LO = Write, HI = Read RS_LCD = 9 ' LO = Command, HI = Data reset_LCD = 8 ' LO = Reset, HI = reset released PAD7 = 7 PAD6 = 6 PAD5 = 5 PAD4 = 4 PAD3 = 3 PAD2 = 2 PAD1 = 1 PAD0 = 0 #1, HOME, GOTOXY ' PST formmatting control #8, BKSP, TAB, LF, CLREOL, CLRDN, CR, GOTOX, GOTOY, CLS VAR long stack[50], frame[400], cntDn byte chr OBJ ' term : "fullduplexserial" ' = FDS ' TV : "TV_text" ' to be used later, maybe vp : "Conduit" ' transfers data to/from a PC; uses 1 cog qs : "QuickSample" ' captures INA, variables; uses 1 cog, samples at 20 MHz ' dbg : "PASDebug" ' Include for PASD Debugger (MUST include binary file) PUB Main ' Cog 0 vp.register(qs.sampleINA(@frame,1)) 'sample INA w/ 1 cog up to 20 MHz (MUST BE COG 0) optional_configure_viewport ' optionally configure Viewport's interface vp.share(@cntDn,@chr) 'share memory from 'cntDn' to 'chr'; END of VP commands <<=== ' Display.start(12) ' " Cog 3 ' id := cognew(@DTbus,@DTarray[0]) ' this sets up the DTbus registers for the DTbus cog ' id := cognew(@entry,@DTarray[0]) ' cog for DTbus R/Ws; Cog 3; PASD; CmdStatus=>StatAsm @ PAR ' id := dbg.start(31,30,@entry) ' Include for PASD debugger (NOTE: PASD needs a 'xxx.bin' file) {{ term.start(RX1, TX1, %0000, 115_200) ' init FDS term.str(string(CLS, "QuickStart LCD test, 15 Aug.2011")) waitcnt((MS_001 * 1000 +cnt)) }} initLCD dira[LED7..LED0]~~ ' LEDs are outputs from Prop ' DIRA[E_LCD..PAD0]~~ ' make P0..P11 outputs on Prop (this just a TEMP use) cntDn := 0 repeat if cntDn == 0 ' check if value reached zero cntDn := $0000_0FFF ' if so, set to FFFh outa[LED7..LED0] := cntDn ' output cntDn value to LEDs OUTA[PAD7..PAD0] := $0000_00FF & cntDn ' output also to LCD's 8 lines chr := $00FF & cntDn wr_LCD {{ term.tx(HOME) term.hex(cntDn, 4) term.tx(CR) }} cntDn := cntDn - 1 ' decrement value waitcnt((MS_001 * 1000) +cnt) ' pause to display for human eyes; ~45 ms loop time by scope '+-------------------------------------------------------------------------------------+ PUB optional_configure_viewport ' FROM CONTROL1 vp.config(string("var:io(bits=[all[0..29],30tx,31rx])")) vp.config(string("var:io,cntDn,chr")) ' show these VARs vp.config(string("lsa:view=io,timescale=10us,trigger=io[16]r")) ' trig on A23 rising vp.config(string("edit:chr(default=5,mode=text),cntDn(mode=text)")) vp.config(string("start:lsa")) '+-------------------------------------------------------------------------------------+ PUB initLCD {{ term.tx(CR) }} DIRA[E_LCD..PAD0]~~ ' make P0..P11 outputs on Prop OUTA[E_LCD..reset_LCD] := $1<<8 ' set E_LCD..reset_LCD (LCD control lines) LO waitcnt(MS_001*2100+ cnt) ' delay about 20 ms ' OUTA[reset_LCD]~ ' release reset line ' waitcnt(MS_001*10 + cnt) chr := $1C ' turn on LCD driver power wr_LCD ' send command chr := $14 ' turn on character display wr_LCD chr := $28 ' set for '2 by 12 char. lines' wr_LCD chr := $4F ' set at darkest contrast wr_LCD chr := $E0 ' set data address to first location wr_LCD OUTA[RS_LCD]~~ ' set RS line Hi for Data transfer waitcnt(MS_001*100 + cnt) {{ term.str(string(CLS, "initLCD done")) term.tx(CR) }} PUB wr_LCD ' enter with RS Hi for Data, LO for Commands OUTA[E_LCD]~~ ' E line Hi to load value ' waitcnt(MS_001 + cnt) OUTA[PAD7..PAD0] := chr ' byte to LCD for Data/Command ' waitcnt(MS_001 + cnt) OUTA[E_LCD]~ ' drop E line to latch the value {{ term.tx(HOME) ' TEMP USE, this, next5 lines term.str(string("wr_LCD = ")) term.hex(chr, 2) term.tx(CR) }} waitcnt(MS_001 * 10+ cnt) ' wait for about 1 millisecond ' 10 ms enough ??? datJim
'OK' is meant that the LSA displays waveforms as expected. 'Not working' means it doesn't configure and thus no LSA display.
@ all, Today I installed ViewPort vdr. 4.6.0. Bummer. I now get a "Problem with conduit version on COM3" error. I tried to verify there are no other conduits in the \lib folder. It is dated 7.16.2011; I suppose that is only the install date, as I downloaded v 4.6.0 several days ago.
Something strange about the Open in VP is quite different than in the Parallax IDE. I had a problem with an old .spin file on the Desktop that could only be seen by VP, yet the IDE could see the newest which was in the Tutorials folder. VP wouldn't let me look into the Tutorials folder!!!
Any clue as to why the 'conduit' problem'?
Yesterday was mostly used up by non-Prop activities. Today I took a closer look and on searching found about a half-dozen Conduit files in various places, one on the desktop. Deleted that one and it finally runs. Not only on my 2-Prop board but also the QuickStart board. I don't know where all those Conduit files came from, but I've gone through a large number of VP versions since Hanno was beta testing VP. I'll delete the others later on, but seeing the ViewPort application run, I'm happy.
For some reason installing ver 4.6.0 showed up this problem. To my knowledge I'd not moved any Conduit file around except to place one in the VP 'lib' folder.
