Communication worldwide — Parallax Forums
RL600RL600 Posts: 40
edited 2011-12-05 04:11 in Accessories
Here RL600,
I want a system for my boe-bot to communicate over the whole planet. Has somebody an idea.
RL600
  • LeonLeon Posts: 7,620
    edited 2011-08-15 12:08
    Use Ethernet. If it needs to be wireless, use a Wi-Fi connection.
  • RL600RL600 Posts: 40
    edited 2011-08-15 13:03
    I need to communicate for example over 60 km. Is WIFI then the right solution? And you need
    the password of the WIFI.
    Is it not possible to communicate over 3G or anything else.
    RL600,
    But many thanks for your reaction.
    edited 2011-08-15 13:12
    I meant that you could use Ethernet and Wi-Fi.
    edited 2011-08-15 13:17
    I have not work so much with Ethernet and wifi do you know something where I can learn to work with it and get the 60 km.
  • Mark_TMark_T Posts: 1,981
    edited 2011-08-29 09:37
    Is a satellite phone connection beyond your budget - its technology that is designed for exactly this problem...
  • John MichaelJohn Michael Posts: 37
    edited 2011-12-03 11:20
    Check out the DroneCell at Narobo.com ...
    There are several Video's on YouTube to get you jump started.
    John Michael
  • TubularTubular Posts: 4,771
    How much data are you sending? You can look at Orbcomm, which is available absolutely everywhere, although you might have to wait a moment for a satellite to pass overhead.
    Its really only cost effective for small packets of data however (eg a position or alarm change status)
