Basic stamp 2 freezes
I am a newbie to this forum, so I hope this is the correct place for this question/post. I have a Basic stamp discovery kit (bs2, boe, books). I have been working on a project (my first) and I think I may have 'sploded my stuff. I am now at the point where my module will run programs for a few seconds and then stop responding. If I try to communicate with the boe I get a message that there are no basic stamps present. If I turn off the board at the switch for a few minutes the module will begin to respond again and then lock up a few seconds or minutes later. I have removed all of the hardware from the bread board except for a 440 ohm resistor and a LED on pin 1.
I load a program like :
HIGH 1
END
When I run the program the LED will light. The module will go to sleep (LED dims every 2-3 seconds). Then after a while the LED goes out. The power supply LED on the boe remains lit. If I power cycle the boe I can repeat this whole chain of events. It does not matter if I have the usb plugged in or not. It does not seem to matter what program I load I get pretty much the same results.
Is there a way I can find out if I have fried the module? Could this still be software even though I have loaded a small, simple program? Sorry for being such a noob.
HIGH 1
END
Does your Stamp get hot? Is your resistor hooked up properly, in series with the LED? How much current is flowing out of the pin? If the Stamp is still working, good, but find the problem before it does burn out.
Remove everything (LED & resistor) and see how long this program runs:
a:debug "hello":goto a
> 440 ohm
>LED
>Vss. Stamp does not seem to be hot or even warm, but I will recheck. A For.....next loop will run 130 times before the debug screen stops reporting. For x =1 to 5000: Debug ? x: Next. I will check the current draw.
Are you using a 9v battery? Check the voltage on the Stamp at the Vdd pin, no hardware plugged in.
