Using high resolution optical laser mice as encoders?
grindel
I recently saw an laser optical mouse advertised as having 5200 dpi (~.0002" resolution ?!)
( http://www.logitech.com/en-us/mice-pointers/mice/devices/5092?debug=0 ) First I would be curious if I could hook it to the prop by simply using one of those usb-ps2 converter dongles ( http://www.amazon.com/Mouse-Female-Male-Computer-Adapter/dp/B0016LJJMW/ref=pd_sim_e_1 ) It occurs to me that this would be a very accurate encoder for a cnc router, reading information right off the side of the rail instead of trying to use a rotary encoder off of the lead screw or somewhere else in the drive system. Is this an idea worth pursuing? I know no-one cares if a mouse drops a pulse or two, so maybe, despite such high resolution, possibly it would not be as reliable as I would hope. Does anyone know if the prop mouse driver could keep up with the information from 3 of these? It seems like it would be in the realm of possibilities.
disclaimers:
My cnc router only exists in my head at this point
I am a horrible programmer, mostly relying on modifying others code to get anything done...
Even if i did get the prop to feed back info to the computer I wouldn't have the skill to integrate it into stepper controls.
I mostly just want to throw it out there and find out if it is a good idea and see if anyone could use it.
disclaimers:
Graham
http://www.usdigital.com/
Bruce
