OEM BS2 stand alone controller?
Hi, I have a problem that to me totally befuddled. I wrote a program that runs perfectly on my Board Of Education and by using a series of jumper wires from P0 through P15 it controls a series of LED lights on a separate much larger breadboard. It is a simple score-keeper. It simply keeps track of a button being pressed and then turning on the next LED and turning off the previous LED. Like I said, it works great. Now the problem. If I disconnect the USB cable from the Board Of Education and repower it back up it works fine all on it's own. If I take the Board Of Education out and replace it with an OEM BS2 module on the large breadboard and run it with the serial cable it works fine. Now if I unplug the serial cable and repower it back up it doesn't run properly. I tried it with 3 different OEM BS2's with the exact same results. Any ideas of what I am doing wrong? This is my first project and I was under the impression that the OEM BS2 module could be used as a stand alone controller. Correct?
Djough
Djough
Also check your power and grounds.
It can be used like any other BS2.
-dan
Djough
You mention using an ATX power supply. Keep in mind that some desktop computer power supplies have a minimum current drain requirement for proper operation. Neither the OEM BS2 nor the BS2 module will draw much current.
Could you have wired all 3 of your OEM BS2 kits improperly? Could you have wired the OEM BS2 kits incorrectly to the breadboard? Remember that the serial cable provides a ground connection. If you don't have some other ground connection, the OEM BS2 may not work when the serial cable is not connected.
