Rs485
RS485 question:
I have a system with 10 props communicating over rs485 using the 75176 chip and a 2n2222 transistor as a level shifter between the prop and the control/transmit pins. This has been working fine for the last year at 9600 b. but now Im looking at the design and thinking maybe I dont need the level shifter and maybe I should be using a different chip. (like the LTC1487). or?...
Also would like to up my baud rate to maybe 56,000.
A little circuit design help would really be appreciated.
Bill
Bill
I often look through Futurlec.com for what is available and cheap because they provide all the PDFs next to the component description and prices. It is at least a good starting point. Linear Technology and Maxim have RS485 line drivers and transceivers in many different specs.
The MAX3362 is a 3.3v RS485 transceiver. So is the MAX3485 at $2.90 from Futurlec.
When I originally designed the circuit I used the 75176 as it was kind of the standard chip and I made the assumption that it was TTL on the interface side (and a 5v device), so I put in the level shifter transistor. But now after reviewing the data sheets for the old chip and some of the newer ones I see the 5v chips all have 2 volts minimum for a high on the interface side. I have 5v regulated on the board also, so its just the prop to transceiver interface in question. Before I order another hundred chips and re-design the board maybe someone has been there done that.
Bill
I prefer to run either the basic MAX485 or generic equivalent (or even some of the better parts which have proper failsafe inputs, but more later) at +5V for greater drive and range. Failsafe inputs on some just means if you leave the lines floating then you are guaranteed an inactive condition on the logic receive line. Proper failsafe ensures that even if the lines are shorted or as is more frequently the case overloaded with termination resistors then the receive will remain inactive. More on this later.
Anyway, this is the circuit and as you can see I always use a pulldown on the TE line which is also tied to the /RE line as well. So in power-up or undefined state the transmit section will be disabled.The 10K resistor in the combined RO/DI line just ensures the current is limited into the Prop when receiving.
Anyway I might run a design tip thread just on RS485 along with some commercial-grade code suitable for the OBEX.
Thanks a bunch! Thats just what I was looking for. My background is power engineering; That is: megawatts and kilo-volts, so microchip interfacing is a little different. I have had a lot of success with the rs485 communications and will probably go with one of the newer chips with static protection and the other extras Thank you for your support.
Bill
