More than 3.3 Volt
In the propeller datasheet, the max specified VDD voltage for the prop is 3.6 volts. If I have an application that really need at least 3.5 volt on the IOs, is it correct to run the propeller at 3.6 volts (even if it is non standard)? This is for a unique prototype.
