Anyone help me with a simple de-bounce idea? — Parallax Forums
MoskogMoskog Posts: 556
edited 2011-08-16 22:33 in Propeller 1
Hello, I have a push button in a simple counter, counting one number upwards each time button is pressed and starting from 1 again after reaching 5.
Like this:
number := 1
repeat
  if ina[button] == %0
    number := (number + 1)
      if number == 6
        number := 1
waitcnt(clkfreq/100 + cnt)
But my problem is de-bounching and I would appreciate if anyone know a simple solution and will help!
  • RaymanRayman Posts: 16,276
    edited 2011-08-11 12:13
    easiest way is to move that waitcnt over so that it is inside the repeat loop...
    Actually, what I think is best is to first wait to detect the key down, then wait for the key to go up, and then wait a while after that for the bouncing to go away...
  • idbruceidbruce Posts: 6,197
    edited 2011-08-11 12:26
    Moskog
    Your waitcnt should be indented. Like so:
    number := 1
    repeat
          if number == 6
            number := 1
    Bruce
    edited 2011-08-11 12:29
    And perhaps a longer waitcnt, depending on the type of pushbutton and contacts.
  • LeonLeon Posts: 7,620
    edited 2011-08-11 12:36
    A typical debounce delay is 20 ms. It varies with the type of switch, though.
  • max72max72 Posts: 1,155
    edited 2011-08-11 14:44
    I used this one with the 5 way switch from Parallax.
    It counts seconds, and performs the debounce on the 5 buttons.
    Massimo
    edit: it runs on a separate cog, stores the keypress and returns the reading in the main code when asked to.
    After reading the button you should "clear" it.
    CON
    onesec = 80_000_000
    VAR
       long timer_stack[40]
       long seconds
       long switch, rilasciato
    PUB start
      cognew(conta,@timer_stack)
    pri conta|previous
      dira[16..20]~
      seconds:=0
      rilasciato:=0
      switch:=0
    '  repeat
    '     waitcnt(cnt+clkfreq)
    '     seconds++
      previous:=cnt+clkfreq
      repeat
         if (cnt-previous)>0
             seconds:=seconds+1
             previous:=previous+clkfreq
         debounce
    pri  debounce|button
      if switch== 0
         button := (!ina[16..20])&%11111
         if (button==0)
            if rilasciato > 0
               rilasciato :=0
         if button>0
            if rilasciato ==0
               waitcnt(clkfreq/100+cnt)
               if button == (!ina[16..20])&%11111
                  switch:=button
                  rilasciato:=1
    pub bottoni
      return switch
    pub clear_bottoni
        switch:=0
    pub tempo
       return seconds
    edited 2011-08-11 15:05
    idbruce wrote: »
    Additionally, you may want to have the routine after waiting for bounce to settle, make an additional delay and retest as a "Yes, the switch was really pushed" to separate accidental from deliberate presses of the switch.
  • JonnyMacJonnyMac Posts: 9,801
    edited 2011-08-12 07:45
    Here's a simple method I use from time-to-time; it let's me specify which pin to use, the state to look for (so it works with active-high and active-low), as well as the debounce duration (in milliseconds). If the pin is held in "state" for the specified period the method returns True.
    pub debounce (pin, state, ms) | t, db
    '' Returns True if pin is held in state (0 or 1) for ms milliseconds
      dira[pin] := 0                                                ' make pin an input
      db := 0                                                       ' clear debounce counter
      t := cnt
      repeat ms
        if (ina[pin] == state)                                      ' if button pressed
          db += 1                                                   '  increment counter
        else                                                        ' else
          db := 0                                                   '  reset counter
        waitcnt(t += clkfreq / 1_000)
      return (db == ms)
    The method always runs ms milliseconds. If you want an early exit, replace the else clause (db := 0) with quit.
  • MoskogMoskog Posts: 556
    Lots of good ideas here, thanks to all for your replies!
