41 New servo's not working! Why? - TowerPro SG-5010 — Parallax Forums
rvdokkumrvdokkum Posts: 2
edited 2011-08-10 17:07 in Propeller 1
I'm using the ''Propeller Servo Controller USB (#28830)''
to control servo motors ''TowerPro SG-5010''
i use a switching adapter of 5V 4A as power suply connected to the servo controller board.
from the 48 servo's i ordered only 7 work.
the others just sit still and make very small random movements.
To test the servo motors i use the ''Parallax Servo Controller Interface v0.9h Beta''
where do i start to clear up this mistery?
all help is welcome,
greetz from Amsterdam / The Netherlands.
    edited 2011-08-10 16:19
    Have you tested all the servos on another controller, or on an RC unit?
    Are they new? Where did you get them from? Did you ask THEM about your problem?
  • schillschill Posts: 741
    edited 2011-08-10 16:23
    Try putting a resistor inline with the signal from the board to the servo (typically the white wire, and labeled W on the PSC). There are several threads discussing this. Here is one of them:
    http://forums.parallax.com/showthread.php?118121-Digital-servo-s-on-USB-servocontroller&p=862005
    This problem can be caused by the level converters (5v <-> 3.3v) used to buffer the signals to the servos. The recommended value is 5K ohm or so. I have used 10K 1/8W resistors successfully.
    In my experience, some servos have worked fine "out of the box" and others have required the resistor.
    edited 2011-08-10 16:41
    At the risk of overstating the obvious, have you checked each servo individually? I can't imagine 41 out of 47 servos in a batch being bad, but that's where I'd start.
    -- Gordon
  • rvdokkumrvdokkum Posts: 2
    1 k resistor in line with the signal did the trick.
    all 48 are working. also the ones that did not need the resistor.
    as i see the staff David Carrier explain in this post :
    The Propeller USB Servo Controller cannot drive loads less with than 5 kΩ of impedance.
