High signal to low signal using ULN2803A darlington array?
Hey,
I just want to make sure this is right before I destroy anything:
I have often used the ULN2803A darlington array chip to trigger a 24V relay from a 5V stamp signal. No problem here. Now I want to do it the other way: 24V to 5V. I did this on a breadboard and it seems to work. A 24V signal to trigger a 5V output. I just hook up 5V to COM and 0V to GND, send 24V on the input side, and sink 5V on the output.
The datasheet (http://www.ti.com/lit/ds/symlink/uln2803a.pdf) says max input is 30V and collector-emitter max is 50V so my setup seems okay. But I haven't been able to find any sources talking about using this chip to go from a high signal to a lower output. Is this really okay?
Blake
Blake
Other than that you're good...
You're close to 30V rating then. Is the chip getting hot when 24V is on for a long time? Verify that. You're using just one input so you should be fine.
Funny idea about the voltage regulator btw. Would it be slow like hell? I wonder what would happen on the output when the 24V rise time is slow too. Just courious...
How about an optocoupler? That's really safe and cheap...
+24---220KΩ---47K---Gnd
Output across 47K = 4.2V
If it's not hot you're good to go...
Actually, that same approach will work perfectly in the other direction 5->24....
Now that I know that you're feeding a digital input with this thing I would recommend to use the 10k pullup to 5V. Since you connected the COM pin to 5V it gave you some weak pullup and therefore you test circuit worked. The diode is too weak though. It will give you something like 10M Ohm or more. That's an order of magnitude too high. If you touch this input with your finger it my transition back to logic '0'. Use 10k there unless you're sure that your digital part has an internal pullup...
Blake
http://www.fairchildsemi.com/ds/H1/H11L1-M.pdf
