stumped: trying to record values from mcp3208 to 27937 data logger
Using a Prop Proto Usb, mcp3208, 4 line LCD, and usb data logger, i'd like to read the 3208, store the values read, and be able to do some simple math, and a couple if/else 's to turn on a relay...
Where i am....
I can read the 3208, and i can display the values received on the LCD. What i havent figured out is how to get the values read, over to the USB for storage...
I've been messing whith "memStick_demo" and have been able to see a file written to the flash drive via the 27397, so i know my parts are working...
Ive also been playing around with "autodatalogger" with limited success....
I've cut and pasted my code together trying to get it to work, but for some reason, i'm just up against a wall, and i'm not sure what to try next...
Here is all of the code i'm using, and a pic of the hardware...
Im wondering if I need this bit .
Where i am....
Project5k
this will read all 8 chanels of a MCP3208 and display them on the 4line LCD
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
TX_PIN = 0
BAUD = 19_200
dpin = 2 'both din and dout of the mcp3208 are connected to this pin on the prop demo board.
cpin = 3 'the clock pin of the mcp3208 is connected to this pin on the prop demo board.
spin = 1 'the chip select pin of the mcp 3208 is connected to this pin on the prop demo board.
rxpin = 6 'Receive pin on the Propeller
txpin = 4 'Transmit pin on the Propeller
ctspin = 7
OBJ
LCD : "FullDuplexSerial"
adc : "MCP3208"
USB : "Autodatalogger"
Var
long filenameaddr
PUB main
adc.start(dpin, cpin, spin, 255) 'Start the MCP3208 object and enable all 8 channels as
'single-ended inputs.
LCD.start(TX_PIN, TX_PIN, %1000, 19_200)
waitcnt(clkfreq / 2 + cnt)
lcdgetready
filenameaddr := string("samples.txt") 'this is the file name
USB.init(rxpin, txpin, ctspin, filenameaddr, 10_000) 'the number is the count of samples per file
usbnamecol
repeat
lcdupdate
waitcnt (clkfreq / 4 + cnt)
usbwrite
pub lcdupdate
LCD.str(string(128))
LCD.str(string("Ch-1 ",133))
LCD.dec(adc.in(0))
LCD.str(string(138))
LCD.str(string("Ch-2 ",143))
LCD.dec(adc.in(1))
LCD.str(string(148))
LCD.str(string("Ch-3 ",153))
LCD.dec(adc.in(2))
LCD.str(string(158))
LCD.str(string("Ch-4 ",163))
LCD.dec(adc.in(3))
LCD.str(string(168))
LCD.str(string("Ch-5 ",173))
LCD.dec(adc.in(4))
LCD.str(string(178))
LCD.str(string("Ch-6 ",183))
LCD.dec(adc.in(5))
LCD.str(string(188))
LCD.str(string("Ch-7 ",193))
LCD.dec(adc.in(6))
LCD.str(string(198))
LCD.str(string("Ch-8 ",203))
LCD.dec(adc.in(7))
pub lcdgetready
LCD.str(string(17))
LCD.str(string(22))
LCD.str(string(12))
pub usbnamecol
'Set up the number of columns to log
' (address, digits, title)
USB.addfield(@adc.in(0), 4, string("Ch-1"))
USB.addfield(@adc.in(1), 4, string("Ch-2"))
USB.addfield(@adc.in(2), 4, string("Ch-3"))
USB.addfield(@adc.in(3), 4, string("Ch-4"))
USB.addfield(@adc.in(4), 4, string("Ch-5"))
USB.addfield(@adc.in(5), 4, string("Ch-6"))
USB.addfield(@adc.in(6), 4, string("Ch-7"))
USB.addfield(@adc.in(7), 4, string("Ch-8"))
pub usbwrite 'this is where i plan to write all the data to the usb...
PRI txstring(address, commabool) | length
{Will transmit a string to be written to the file
commabool determines whether or not to add a tail comma}
serial.str(string("WRF "))
serial.tx(0)
serial.tx(0)
serial.tx(0)
length := strsize(address)
if commabool
length++
serial.tx(length)
serial.tx($0D)
serial.str(address)
if commabool
serial.tx(",")
serial.tx($0D)
repeat until serial.rx == $0D
I haven't gone through your program completely but my bet is you're trying to store the data as straight data. You probably need (well want) to convert your data to ASCII characters. The LCD.dec method does this for you when you display the data to the LCD. You want a method that will convert the data to ASCII characters before you write them to the datalogger. Look at the dec method to see how this is done.
If you are still having problems I'll look around for some code that does something similar to what you're doing and post it.
Duane
I think that would work if you're using something like FullDuplexSerial in UART mode.
I'm sitting here looking at the code, and i'm a little unclear, it seems to me that with the way i have things now, i would be asking "fullduplexserial" to communicate to 2 different devices... how do i do this without sending the wrong thing to the wrong place?
do i set a second fullduplexserial up under another um, i dont know what to call it, abbreviation... like this
go from :
OBJ
adc : "MCP3208"
to
OBJ
adc : "MCP3208"
usb2 : "FullDuplexSerial"
i guess i'm just confused how to share it, and get the right variables to the right place at the right time...
i supposed then the code would look more like
usb2.dec(adc.in(0))
usb2.tx(13)
but it seems to me that somewhere above that i would need to start or init or something the usb2 one to send it its variables... wouldnt i?
also, i'm not understanding the (13)... i'm just not finding the right ref... is that a command like move to position on an lcd?
tea_party_is_bad : "FullDuplexSerial"
and the second instance
blabla : "FullDuplexSerial"
of course each instance of FullDuplexSerial must be started through
tea_party_is_bad.init(rxpin, txpin, ctspin, filenameaddr, 10_000)
blabla.init(rxpin, txpin, ctspin, filenameaddr, 10_000)
For each USB-stick you have connected you need one instance of FullDuplexSerial
As you have only one USB-stick one instance is enough.
the above examples are just to show that you are free to choose a name which is some kind of an alias for the "FullDuplexSerial.SPIN"-objectfile
If you want further advice please attach your WHOLE project to a psoting using the archive-function of the propeller-tool.
and additionally attach the manual of your 27937 data logger.
Without seeing your complete code and without knowing the methods of AutoDataLogger advsing is not advising but guessing through the fog.
keep the questions coming
best regards
Stefan
also was poking around and figured out that something in the usb.init is causing the lcd to not display... when i comment it out, the lcd works again...
In principle you did the right thing with archiving the code.
Anyway this archive does not contain code that has to do with the datalogger.
So you might have archived an earlier version of your code.
For archiving the right code. Close all windows in the propellertool except the one containing the USB-datalogger code.
If starting the USB-datalogger stops the LCD. Two things are possible:
You are using the same IO-pins for LCD and datalogger
you are using the same instance of FullDuplexSerial.
For a real analyses that codeversion that is causing the problems must be uploaded
best regards
Stefan
Duane
i have my pin settings in the CON block, but i'm starting to wonder if i'm calling to something, like the usb init, that has pin settings in it, and its ignoring that i'm "sending" it...and this is where my issue is... gotta stare at it for a while....
something else i thought of, just as i was drifting off to sleep last night... i'm reading from the adc to the lcd, and i'm also gonna wanna use thoes readings for math, decision making, and storage... would i be better off to figure out how to read in from the adc into a set of variables, like num0, num1, and so forth, and then just use thoes var's in everything else? then that way i can display them the way i want, i can store them the way i want, in F deg, not counts that dont mean anything to me.... only ready from the adc once, do my display, math, and storage, and then read from the adc again, not read adc, display, read adc, math, read adc, store, and so forth... plus doing it that way, would mean that the math, display, and stored values could all be different... not what i want at all... thats for sure...
Your idea of reading the ADC-channels once and store the values into variables is the right way.
Independant from that the object Autodatalogger needs pointers to variables. You get the pointer to variables by adding the "@"-operator to the variables name.
coding
USB.addfield(@adc.in(1), 4, string("Ch-2"))does not work at all because "adc.in(1)" is not a variable but objectname.methodname(parameter) which is something complete different than a variable.
As you coded this I recommend to go through the exercises of the PE-kit labs. This will take some time but will pay off a lot in the end.
At the moment your knowledge is at a level that you do "graphical copying" things without understanding what it means.
If you stay on that level allmost every detail that you change will end up in
- it does not work - ask in the forum - try a new variant it does not work - ask in the forum - try a new variant and each step will take two days.
Until it is running there will be 15-30 steps meaning 30-60 days. So taking 14 days time to go through the PE-Kit labs and then another 7 days to get it working will be faster.
About PIN-assignment:
If two objects like in your case USB (Autpdatalogger.spin) and store (FullDuplexSerial.spin) are using the same pins as you coded
They will disturb each other and nothing will work.
You have to decide between using the autodatalogger-object or using the FullDuplexSerial-obect together with hand-coded commands to store data on the USB-stick.
The filename (FullDuplexSerial.spin) can stay the same. Only the object-aliases (in your code "LCD" and "store" need to be different. That is enough.
Again these two example shows your lack of understanding.
If I write this - this is never never never meant as beating you. It is meant as clearly stating what I can conclude about your knowledge-level from your code.
And based on that recommending going through the PE-Kit labs.
You are very welcomed to ask hundreds of questions about the exercises in the PE-Kit Lab as this way your understanding and knowledge grows continually up from a basic level.
It's like before you can drive a F1-racecar you have to do some exercising in a motorised go-cart, a F3-car and then switch over to the F1-car.
best regards
Stefan
thanks for helping me thus far, i'll keep tinkering with it, as i've already figured out how to read in the values from the adc, assign them to a variable, and then read that variable out to the lcd...
time to hit the books...
I'll be back...
can someone please "splain it to me lucy"??
PUB dec(value) | i, x '' Print a decimal number x := value == NEGX 'Check for max negative if value < 0 value := ||(value+x) 'If negative, make positive; adjust for max negative tx("-") 'and output sign i := 1_000_000_000 'Initialize divisor repeat 10 'Loop for 10 digits if value => i tx(value / i + "0" + x*(i == 1)) 'If non-zero digit, output digit; adjust for max negative value //= i 'and digit from value result~~ 'flag non-zero found elseif result or i == 1 tx("0") 'If zero digit (or only digit) output it i /= 10 'Update divisorvariable i works as the divider.
I will use lower values to explain it
let's say i := 1000
let's say variable (value) is 7082
if value => i in my example if 7082 => 1000 this is true "=>" means bigger as or equivalent
tx (a ASCII-coded byte)
value / i 7082 / 1000 = 7 why not 7,082? because it s integer math truncating the digits behind the decimal point
first digit of 7082 is 7
theASCII-code of character "7" is 55
ASCII-code of "0" 48
ASCII-code of "1" 49
ASCII-code of "2" 50
ASCII-code of "3" 51
ASCII-code of "4" 52
ASCII-code of "5" 53
ASCII-code of "6" 54
ASCII-code of "7" 55
ASCII-code of "8" 56
ASCII-code of "9" 57
+ "0" gets compiled to + 48 through the hiphens "" the compiler knows you mean it ASCII-coded and ASCII-coded value of character "0" is 48
so value / i + "0" means
7 + 48 = 55
value // i "//" is an operator 7082 / 1000 = 7 rest 82
other examples
81234 / 1000 = 81 rest 234
724 / 1000 = 0 rest 724
got to go to work now
best regards
Stefan
7 + 48
The autodatalogger object is intended to be the sole user of the Datalogger, but if you want to you can trade off access between autodatalogger and your own access code.
Based on your first post, the code below should be a rough framework (untested and uncompiled and from a hazy memory of how things should work...).
VAR long datasample OBJ ADC : "MCP3208_fast" USB : "autodatalogger" LCD : "FullDuplexSerialPlus" PUB Main 'start ADC here 'start LCD here 'init USB here waitcnt(clkfreq*2 + cnt) USB.addfield(@datasample, 4, string("datasample_variable")) USB.start repeat 1000 datasample := adc.in(channel) LCD.tx(cls) 'cls is the clear screen code for the lcd... waitcnt(clkfreq/100 + cnt) 'most LCDs require a pause before sending the next command after a cls LCD.str(string("datasample == ")) LCD.dec(datasample) waitcnt(clkfreq/10 + cnt) 'slow down the loop to ~10 HzAlso, if you are looking to having lots of ADC inputs then take a look at the attached code. It automatically samples from three MCP3208 ADCs, and you can tie the output of that to the input to the autodatalogger in addition to using the values in your math equations however you want.
