Camera Feed Through Xbee
Hello
Anybody know if you can send video through the Xbee? [using the camera parallax sells stock #28317]
Thank You!
Thank You!
You could send images over the link. You could use one of those JPEG cameras and send the JPEG file over the XBee link. You'd need a way of putting the picture back together (and a way to display the JPEG).
Another option is to use very low resolution video (and probably a slow frame rate). I've been working on a project using Hanno's video capture method. For fun I made a really low resolution display with 120 red LEDs. I can display the image from a video camera on this low res display. The brightness of each LED is given by an 8-bit number (byte). 120 bytes are needed for each image (or frame) displayed. Instead of 30fps lets shoot for 15fps. That gives us 14,400 bits per second to transmit. I don't know if a XBee can transmit 14.4kbps. I think if you adjusted some of the settings you might be able to get it to transmit that fast. I'm pretty sure the nRF24L01+ Nordic modules could easily keep up with that rate. It's hard to tell what you're looking at with only 120 grey scale pixels though.
A much easier solution would be to buy a video transmitter and receiver from Deal Extreme.
Duane
-jakethesnake
