USB to serial cable with SXkey
Help needed urgently. I am using a USB to serial cable by Jetion to communicate with my old SXKey from 2000, but the only available port shown is port 8, which is not seen after compilation when I try to run a program. Please Help.
This is the one.
It should be possible to change the port number assigned to your device by using the Windows "Device Manager". How exactly to do that depends on which version of Windows you are using. Try Googling "change usb com port"
You basically expand on "ports" in Device Manager, then select your device and click the "Advanced" button. You should find the com port selection there.
