Difference between BS2 Rev G and BS2 Rev F
Good day! Im just new here
I was just wandering if there is a difference in programming between BS2 Rev G and BS2 Rev F. Also, I am using a 433mhz transceiver.
When I use the Rev G as a receiver, the output in the debug is okay but the output is not stable. The servo motor is fluctuating.
But when I use the Rev F as a receiver and the Rev G as a transmitter, the output in the debug is not 0 1, instead random numbers. The output also is not stable and the servo motor is fluctuating also.
Can somebody tell me if there is a difference in programming the 2 BS2.
Thanks in advance.
Thanks in advance.
Use the Go Advanced button to attach files to a message.
If you're powering the Stamp from Vin (to the Stamp's Vin), you have a grounding problem since the ground reference for Vin has to go through the bridge rectifier before it becomes Vss. Depending on Vin, that can cause the Stamp to reset, particularly in the presence of noise from the servo.
