Prop Chip Photo
Can anyone post a photo or a link to a photo showing the back side of the smallest Propeller chip (44-Pin QFN Chip)? The photos I've seen only show the front side and there's nothing to see on the front side. Thanks!
There's nothing to see on the front side of the
Parallax Propeller QFN chip. What does the back
side look like?
http://www.parallax.com/Store/Microcontrollers/PropellerChips/tabid/142/CategoryID/18/List/0/SortField/0/Level/a/ProductID/333/Default.aspx
The P8X32A-M44 is most useful for prototyping in its 44-pin QFN package. Connecting the Propeller module to your computer's serial or USB port using our Prop Plug for programming is quite simple. The Propeller chip can run on its own with a power supply, internal clock and using RAM for code storage. Add an external EEPROM for non-volatile code storage.
side look like?
They are supposed to be attached with solder paste applied to the PCB with a stencil and reflow soldering. I've managed similar QFN devices with my Metcal soldering station with a large via for the central pad, feeding solder into it with a large tip cartridge.
http://zone-8.com/icm/product_info.php?cPath=&products_id=7983&osCsid=6aa7a9b878daf0ec5704471905f4e43b
Mark_T:
Thanks for the link. I did first try a Google image search but not surprising the image didn't show up. For some reason it was blocked in China. But this direct link gives people living in China the opportunity to unblock it.
Just a large plated hole.
