changing individual bits in a byte?
I have a challenge that i cant get past at the moment.
here is a snippet of code....
There is the setup...
What i am expecting to have happen in this code is the following-
For example if bit_0 and bit_1 on MotionScan were high, i get $0001_0001 as the output when i display variable ZoneMotionFlag.
I then went on to add the IF statements for bit_2 and bit_3 of the test against MotionScan. They dont write to ZoneMotionFlag correctly either.
ANY IDEAS as to why this is not working the way i had hoped?
CON
'BIT MASKS
ZoneMask_0 = $0000_0001
ZoneMask_1 = $0000_0010
ZoneMask_2 = $0000_0100
ZoneMask_3 = $0000_1000
ZoneMask_4 = $0001_0000
ZoneMask_5 = $0010_0000
ZoneMask_6 = $0100_0000
ZoneMask_7 = $1000_0000
ADDRRLY = 56 'PCF8574A I2C Address (A0, A1, A2 all pulled low)
ADDROPTO =63
CLS = 0
PresetOnTime = 30
VAR
long longHIGH,longLOW,MM_DD_YYYY,DW_HH_MM_SS 'Expected 4-contigous variables
byte Buffer[BUFFER_SIZE]
LONG currentTime
Long ontime
Long offtime
byte Today
byte ZoneTimerFlag ' if the bit is high, it means that the timezone states that it should be on
byte ZoneMotionFlag 'if the bit is high, it means that the motion was triggered in this zone. requesting it to turn on.
long ZoneMotionTimer[6] ' this is to store the times for the motions
long MotionScan
byte RelayState
PUB MotionStatus | RunTil, currentH, currentM
' Read inputs
MotionScan:= IO.IN(ADDROPTO)
currentH := (RTC.gethour) * 100
currentM := (RTC.getminutes)
PlxST.str(string(" OPTO READING = "))
PlxST.bin(MotionScan,8)
PlxST.char(13)
IF (MotionScan & |< 0)
'RunTil := currentMinute + 30
IF currentm > PresetOnTime
currentm -= PresetOnTime
currenth += 100
PlxST.dec(currentm)
RunTil := currentm + PresetOnTime
RunTil += currentH
IF RunTil > 2400
RunTil -= 2400
ZoneMotionTimer[0] := RunTil
ZoneMotionFlag |= ZoneMask_0
IF (MotionScan & |< 1)
currentm := currentm - PresetOnTime
currenth := currenth + 100
PlxST.dec(currentm)
RunTil := RunTil + currentH
IF RunTil > 2400
RunTil := RunTil - 2400
ZoneMotionTimer[1] := RunTil
ZoneMotionFlag |= ZoneMask_1
IF (MotionScan & |< 2)
PlxST.dec(currentm)
IF RunTil > 2400
ZoneMotionTimer[2] := RunTil
ZoneMotionFlag |= ZoneMask_2
IF (MotionScan & |< 3)
PlxST.dec(currentm)
IF RunTil > 2400
ZoneMotionTimer[3] := RunTil
ZoneMotionFlag |= ZoneMask_3
PlxST.str(string(" ZoneMotionFlag = "))
PlxST.bin(ZoneMotionFlag,8)
PlxST.char(13)
First the Input board is sampled and it populates variable MotionScan (this works correctly)
Then it starts with the first IF statement where we do a test on the state of the LSB, Bit 0 of the byte MotionScan. If it is a 1, we capture the time, add a preset amount to it (30) and then set bit 0 high on the byte ZoneMotionFlag.
Then the next IF where it is checking the next bit, bit_1 in the MotionScan and then proceeds like above. This is where we start to have problems. When This scenario is true and it goes to create bit_1 high on variable ZoneMotionFLag.
