Beginner PWM questions — Parallax Forums
TtailspinTtailspin Posts: 1,326
edited 2011-08-04 21:29 in Propeller 1
I would like to try out the PWM options on this H-Bridge circiut that I have etched and assembled from this schematic...
I made two of these circuits side by side on the same board...
It works great with the "roomba" motors I have, and also some little 3volt motors that draw almost 3 amps.
Here is what I am trying to do...
I can make this work without using PWM on the ENA* pin,(i.e: only set ENA* pin as an output, and make it output low, 0 volts)
The code without PWM is simple enough... outa[13..8] := %100100 makes the two motors go forward as expected,
But when I try my brand of PWM, the results are not what I expected...
CON
        _clkmode = xtal1 + pll16x                       'Standard clock mode * crystal frequency = 80 MHz
        _xinfreq = 5_000_000
        scale = 16_777_216                         ' 2³²÷ 256
PUB Main | pin
      'Configure counter modules.
  ctra[30..26] := %00110                     ' Set ctra to DUTY mode
  ctra[5..0] := 8                            ' Set ctra's APIN
  ctrb[30..26] := %00110                     ' Set ctrb to DUTY mode
  ctrb[5..0] := 11                           ' Set ctrb's APIN
  dira[8..13]~~                              ' Set Pins to output
  start
PUB start
    PWMForward(30)
    Brake(40_000)
    PWMReverse(30)
PUB PWMForward(distance) | duty
  repeat distance
    repeat duty from 200 to 255              ' Sweep duty from 0 to 255
      frqa := duty * scale * 2               ' Update frqa register
      frqb := duty * Scale * 2               ' Update frqb register
      outa[10..9]  := %10
      outa[13..12] := %10
      waitcnt(clkfreq/600 + cnt)             ' Delay for 1/???th s
PUB Brake(distance)
  repeat distance
    outa[13..8] := %110110
PUB PWMReverse(distance) | duty
  repeat distance
      outa[10..9]  := %01
      outa[13..12] := %01
.....................................................pin 13, 12, 11,.....10, 9, 8
PWMForward "looks" like it is working..... 1, 0, PWM1, 1, 0, PWM1
PWMReverse "looks" like it is working......0, 1, PWM1, 0, 1, PWM1
Brake should look like the chart................1, 1, PWM0, 1, 1, PWM0
but Brake does not work as it did before... 1, 1, 1, 1, 1, 1 all the pins come on for the (distance).
So my question is, How would/should I go about making 4 pins a solid 1 or 0, and 2 pins PWM at the same time?
from the same SUB? (i.e.: SUB PWMForward(distance), SUB PWMReverse(distance) ect, ect...
Thanks very much
-Tommy
600 x 376 - 31K
800 x 600 - 269K
451 x 371 - 35K
    edited 2011-08-04 17:08
    I'm a bit confused, what's the difference between PWM1 and PWM0?
    Before braking you run PWMForward which leaves the DUTY counters running with $FE000000 which is pretty much high all the time (so may look like a solid high). As outputs from outa, phsx and video h/w are ORed together you will keep seeing the forward PWM also during brake. If that's not what you want you'll have to disable/reprogram the counters temporarily.
  • AribaAriba Posts: 2,697
    edited 2011-08-04 17:58
    You make the PWM with the DUTY mode of the counters. I think this is not possible with this circuit. The DUTY mode generates very short pulses (12.5ns) which will not drive the Transistors full on or off thru an Optocoupler.
    You need much slower PWMs. Here is a possible solution with two 10 kHz PWMs:
    CON
    VAR
      long cog
      long pwm1, pwm2, period
      long stack[20]
    PUB Main | pin
      period := clkfreq / 10_000                 ' 10kHz PWM frequency
      cog := cognew(pwm_cog,@stack)
      dira[9..10]~~                              ' Set Pins to output
      dira[12..13]~~
      start
      pwm1 := pwm2 := -1                         ' min. PWMs
      repeat                                     ' keep pins alive
    PUB start
      repeat
        PWMForward(30)
        Brake(40_000)
        PWMReverse(30)
      outa[10..9]  := %10                        ' set forward
      outa[13..12] := %10
      repeat distance
        repeat duty from 0 to period step 20     ' Sweep duty from min to max
          pwm1 := duty                           ' Update pwm1 register
          pwm2 := duty                           ' Update pwm2 register
          waitcnt(clkfreq/500 + cnt)             ' Delay for 1/???th s
    PUB Brake(distance)
      repeat distance
         'waitcnt ?
      outa[10..9]  := %01                        ' set reverse
      outa[13..12] := %01
      repeat distance
    PUB pwm_cog : time                           ' 2 x 10kHz PWMs in own cog
      ctra[30..26] := %00100                     ' Set ctra to NCO mode
      ctrb[30..26] := %00100                     ' Set ctrb to NCO mode
      frqa := frqb := -1                         ' negative pulse
      dira[8] := 1                               ' Set pins to output
      dira[11] := 1
      time := cnt + period
      repeat
        waitcnt(time)
        phsa := pwm1                             ' pwm values: 0..period
        phsb := pwm2
        time += period                           ' next cnt time
    Andy
    @ kuroneko, Sorry for the confusion, I had Pulse Width Modulation on the brain, and got a little overzealous with my PWM's..:innocent:
    Thank you for your explaination, that is exactly what was happening, just as you described...
    and your explaination helped to fill in some of the holes I was digging for myself. :smile:
    @ Ariba, it's allmost like you enjoy writing code...:cool:
    Thank you for taking the time to write that, especially code like that, all commented and everything.
    And it works great, just needed some adjustments to the Khz (10 was a little "chunky")
    I increased the period to := clkfreq / 30_000, So that makes 30kHz PWM frequency? correct?
    Trying to be cog "stingy" and make all of the motor "stuff" stay in one cog, so I will maybe move some
    things around, and try to use just one cog, I run out of cogs fast, with my roaming robots...:smile:
    Anyway, after realizing I had PWM on the brain, I tried just toggling the pins...
      repeat distance
          outa[10..9]  := %10
          outa[13..12] := %10
            !outa[11]
            !outa[8]
            waitcnt(clkfreq / 405 + cnt)         ' Change number to control motor speed
            !outa[11]
            !outa[8]
            waitcnt(clkfreq / 505 + cnt)         ' Change number to control motor speed
    I think I was stepping thru what amounts to PWM,? :confused:
    Again, thanks for the help, I love this forum.
    -Tommy
