Reading pulse from RC receiver
I'm experimenting a bit with using a Hitec Optic6 transmitter with a Hitec receiver connected to Propeller Robot Control Board on a Stingray. The goal is to drive the robot with the remote, and with some as yet undefined mechanism like another channel or control function, switch between direct control of the robot with the Hitec transmitter and ai onboard the propeller/stingray.
I'm working on reading the pulse duration from the RC receiver. After I'm satisfied with the read from the receiver I will map a couple channels to the motor control on the stingray.
I've bingled the forums a bit and come up with these ideas previously discussed. Have I missed any objects or code that might be useful to me or other discussion threads?
The BS2_functions I found on Obex was a single .spin file. Is there another distribution with examples? I'm interested in using the Pulsin command. The source has this comment refering to: "See distributed example"
BS2_functions
Dual RC Servo Pulse Width Measurement Driver
Radio Override
Simple Radio Control Capture & Repeat to Servo
RX input / RC Receiver Input
jm_servo8_measure_test - Archive [Date 2010.12.21 Time 18.35].zip from this thread http://forums.parallax.com/showthread.php?128142-Polling-8-RC-receiver-channels-with-still-easy-to-understand-PASM-code
http://forums.parallax.com/showthread.php?128336-PPM-protocol-RC-tranmitter-module-control
http://obex.parallax.com/objects/522/
http://obex.parallax.com/objects/592/
http://obex.parallax.com/objects/401/
PUB PULSIN (Pin, State) : Duration {{ Reads duration of Pulse on pin defined for state, returns duration in 2uS resolution Shortest measureable pulse is around 20uS Note: Absence of pulse can cause cog lockup if watchdog is not used - See distributed example x := BS2.Pulsin(5,1) BS2.Debug_Dec(x) }} Duration := PULSIN_Clk(Pin, State) / us / 2 + 1 ' Use PulsinClk and calc for 2uS increments
BS2_functions
Radio Override
I have used most of those objects at one time, experimenting. My favorite is RX input / RC Receiver Input by W9GFO (Rich Harman). You have "bingled" well and found most of what is out there I think. I'll look at my notes and see if I find anything you have missed.
Ron
Here is a screen shot of Viewport monitoring channels/pins 1-4 as input and 4 channels out on pins 7-10.
I started a thread in the General forum soliciting suggestions for a motor controller that I might use instead of the onboard L6205 H-Bridge driver. An interesting reply from Parallax too.
http://forums.parallax.com/showthread.php?133716-Suggestions-for-motor-controller-for-Stingray-project&p=1026082#post1026082 I'm looking for suggestions for a motor controller.
I also received a 2.4g ntsc wireless video camera and receiver a couple days ago so I can see where I'm going.
