PWM, MOS, and the propeller as a heated bed regulator
I'm investigating the possibility to build a heated bed for the 3D printer.
I'm intrigued by the PCBs with Al substrate.
So my idea is to use the tracks to heat the PCB, add a PT1000 or similar sensor, and control the current on the PCB tracks with the Propeller, and the IRF3708 Mosfets.
I would like to know if I can control the heating using PWM with the Propeller.
It could be possible to have more than 1 heating circuit controlled by independent MOS. Would this approach be preferable? This way I could have a part of the heating circuit ON all the time, and control only a part with the PWM.
Thanks in advance,
Massimo
Thanks in advance,
Massimo
You may require a high power low value series resistor to set some sort of current limit. If you do, make sure you can also use the heat from it too.
I haven't checked your Mosfet.
In fact I got inspired by the various solutions available on the Rep Rap forum. There are nice track resistance calculators available on the net.
I was also considering some sort of thermal switch as a safety measure. Could it work?
Massimo
