3.3V LDO Regulator / Power Supply Topology Advice
I'm looking to add a 5V rail to my project and will need to then step down from 5V-->3.3V for the propeller and peripherals.
I'm currently considering the NCP4589. Any thoughts for/against this choice or any other recommendations I should consider?
My power supply topology would be as follows:
6-15Vin --> LMZ12001 Switching Reg configured for 5V@500mA --> NCP4589 @ 3.3V --> Propeller etc.
My goal is for the switcher to manage the majority of the regulation as efficiently as possible and take the hit on the 5-3.3V drop.
Is this a solid approach?
Anyway check carefully the capacitors requirement and current rating. Probably current rating is not a big issue, but the capacitors are chip dependent, so datasheet handy...
Check the boards available from parallax or gadget gangster. They have both types, and with a high current rating.
For instance the propeller platform uses LD1086 or LD29150 depending on the mounting option.
Parallax sells this one:
http://www.parallax.com/Store/Components/IntegratedCircuits/VoltageRegulator/tabid/615/CategoryID/80/List/0/SortField/0/Level/a/ProductID/473/Default.aspx
An SMD I used the TC1262, it is small and friendly (it requires small capacitors).
Massimo
I believe the regulator on the Parallax Demo Board provides all three. You might take a look at the LM2939IMP-3.3. That may be just the surface mount version, but check the PDF for packages.
Thanks for the info.
Will do. The google hits on that one are interesting...
