Newbie who is lazy and has a question
Someone gave me a couple of the BS2P40 which I want to mess around with.
Is there a cheap eval board to plug that into and mess around a bit? I am looking to pad a Digikey order today.
Its been a while since I have used anything from Parallax.
Chip if you are reading this its been a long time since we used to chat all the time
when I used to use you programmers and emulators.
Dave
Dave
If you're looking for inexpensive, you could wire it up on a full sized breadboard - https://www.adafruit.com/products/239
You would need to buy or build a cable to program it with.
That was what I concluded looking at the website.
I guess noting is easy.
Thank you.
Dave
Once the Stamp is programmed you move it to an appropriate receptacle (or bread board).
Again, I'm not sure about this.
Duane
Thanks. Having a look at the pinouts that might work.
Dave
Dave
I would probably use an intermediate socket to protect the pins.
Please pass on my greetings to Chip when you see him.
Dave
