Using 433 MHz RF Transceiver — Parallax Forums
Kris CardoenKris Cardoen Posts: 46
edited 2011-08-01 13:12 in BASIC Stamp
I'm quite new to robotics and just started working with the boe-bot kit.
I was wondering if it is possible to upload new code to the boebot without connecting and disconnecting the USB cable?
I found an 433 MHz RF Transceiver, that can be added to the boebot. Can this connection also be used to upload new code?
Kris
  • Tom CTom C Posts: 461
    edited 2011-08-01 04:32
    Kris,
    You might want to consider this transreceiver for uploading code to the BOE: http://www.bluewolfinc.com/pages/FlashFly-System.html
    Just a thought.
    TCIII
    edited 2011-08-01 06:54
    No, most wireless links can't be used to download programs to a Stamp. There are timing problems. The FlashFly System is designed specifically to be able to download programs to a Stamp.
  • Kris CardoenKris Cardoen Posts: 46
    edited 2011-08-01 08:36
    >Thats just what I was looking for! :smile:
    One mor question however. It's not very clear to me if the kit without XBee can function wireless or do you need the XBee for that?
    FlashFly USB Kit without XBee's + XBee Series 1 (with wire antenna) ?
    Thanks for your help
    Kris
    edited 2011-08-01 09:08
    You have to have the xBee device too.
    Kris/Mike,
    I have the RS-232 version of the FlashFly System and it works very well.
    The modules went together easily and worked the first time that I turned them on.
    However, the documentation concerning the custom programming of the Xbee 2.4GHz Pro modules is kind of sparse.
    If you buy the FlashFly System with the Xbee modules, you might want to have BlueWolf program them for you. Though I had no problem doing the Xbee programming using X-CTU.
    TCIII
