Booting the Prop from low voltages, 3 of 3: Meyer Lemon @ 0.42V
Tubular
As Mark_T correctly guessed, the final energy source in this LTC3105 series is the humble lemon.
The lemon by itself didn't provide enough "juice" (current) to boot the prop. It needed a "lemon-aid" in the form of a cap/supercap to charge up to 0.42V before the LTC3105 could work its magic.
The two electrodes I used were a strip of single sided copper clad pcb material, and a #14 gauge galvanized bugle bolt. This produces a potential difference of about 1 volt. The short circuit current I measured at about 600 microamps initially, but it reduces as the reaction progresses.
Charging the 0.9F supercap took something like an hour, before the voltage read 0.42V. The LTC3105/Prop combo was then connected, booted, and operated (flashing a blue led in RCSLOW) for about 2 minutes before the cap voltage dropped below the minimum 0.32V.
But as truth would have it I'm stuck with a Meyer tree, overflowing with fruit despite the busy efforts of the citrus gall wasp.
At least I have a good use now for all those lemons in powering prop circuits, or testing LTC3105 boards.
Admittedly this was an exceptionally small geared motor and it could only just rotate an attached cocktail umbrella but I hate to think what we were drinking everyday then.
Booting the Prop would have been a doddle.
Back in 1990 we were being moved out of the dedicated OB base and back into the studio block and I happened to be out in the garage when this guy from the water board turned up. He asked to read the meters, at first I just told him where they were but then turned back and enquired what he meant by "meters". He then explained that we had two sorts of water supplies, one was domestic (drinking) and the other was industrial.
I then realized that for the previous eight years the water that we had taken up the Welsh hillsides for teas and coffees was the stuff directly from the local docks. Probably explains a lot.
(As for lemon power, I was told a while back to stop being so exotic, and use spuds instead)
