Prop and the Parallax DataLogger - Issue writing to a text file
What I am trying to do is read from a file (Input.txt). Store the individual Bytes into a free range of RAM. Read from the same region of RAM into a new file text file (Output2.txt). then light up LED's on a board in the order of 1 2 3 ...
This is proof of concept for me before I can write my real program.
My program works, but Section 3 when I write to Output2.txt I get garbage in the file. What am I doing wrong?
Input.txt contains: 123456123456CRLF
Output2.txt contains:
¬#¤ð
¬#¤ð
¬#¤ð
¬#¤ð
'Section 1
logger.flush
logger.changeDirectory(string("\"))
IF logger.openFileForRead(string("Input.txt"),0)
logger.seek(USBOffset)
logger.readFromFileUntilChar(string("Input.txt"),@arrUSBBuffer,CR,@USBOffset)
logger.closeFile(string("Input.txt"))
lcdout.cls
lcdout.str(lcdnum.dec(USBOffset))
WAITCNT((CLKFREQ + 2) + CNT)
'Section 2
Repeat I from 0 to (USBOffset - 1)
lcdout.cls
WAITCNT(CLKFREQ / 4 + CNT)
arrString[0] := arrUSBBuffer[I]
IF arrString[0] == CR
arrString[0] := 65 ' A
lcdout.str(@arrString)
Byte[$39D0][I] := arrString[0] 'Write data to region of free memory
ELSE
lcdout.cls
lcdout.str(string("Error...", CR))
'Section 3
IF logger.openFileForWrite(string("Output2.txt"),0)
'logger.writeToFile(string("ABCDE"),5,0) 'Works but not used
Repeat I from 0 to (USBOffset - 2)
ID := Byte[$39D0][I]
'ID := ID + 48
logger.writeToFile(ID,1,0)
logger.closeFile(string("Output2.txt"))
ELSE
lcdout.cls
'Section 4
dira[LEDs_START..LEDs_END]~~ ' Set entire pin group to output
ID := ID - 32 'LED's start at D17 - D25 to compensate -48 (ASCII) + 16 (Target) = D17
outa[ID] ~~
waitcnt(clkfreq + cnt) ' Wait 1 second -> 1 Hz
outa[ID] ~
logger.writeToFile(@ID,1,0)
