BST handicap
I'm starting to use bst and got it to compile my file, but find no menu item that allows printing.
Is there a problem with the Mac OSX and printing from bst?
Copy/paste to some other app that can print is a hassle. Formatting isn't nice and font size is weird.
Anyone understand this problem?
I'll have to look into that ("I use the emacs propeller-mode to print."). I have no idea what 'emacs propeller-mode' refers to.
@ all
I find after getting a very small program to compile and load to EEPROM, 'bst' can no longer find the Prop. What might this be due to? There are two ports found on Rescan but neither sees the Prop. Don't know if I'm holding my tongue right (or left)! Anyone run across this problem before. The QuickStart board is powered and connected and runs its program from EEPROM, The connection is iMac to 4 port hub and the QS board plugs in there. Never found this problem using Parallax's IDE.
