Worm Gear Box Versus Regular Gearbox When Power is Cut
With a regular gear box the output shaft can turn the input shaft. So cutting motor power results in the momentum of the robot being transferred back through the gearbox to the motor. Useful if your H-bridge supports dynamic braking as you can bring you robot to a speedy halt.
However a worm gear box only allows a one way transfer of power. So I'd assume that if you cut the motor power the output shaft should lock up once the residual momentum within the motor is consumed. So at this point what happens to the robot?
The only good things I can say about worms is they are compact, use fewer parts and are self-locking.
In my project video you can kinda make out when it is coasting.
Ron
Rich H
That's the same one I have. I was thinking they would be good for an arm because they wont move without power. Unless something bad happened.
It uses the the Tamiya worm gear motors instead of the double gearbox which is commonly used. So I began to wonder if the locking of the worm gear box provided some advantage. Particularly because some low end h-bridges only have a enable and direction line which means they can't brake the motor.
Yes, these motors will provide some braking, and they will lock. These motors are capable of a little more torque than the twin motor gearbox and similar designs. They use a beefier RE-260 size motor, and the gears are thicker. Of Tamiya's high torque motor kits the worm gearbox has the distinction of being the most slender -- the main advantage of worm motors, after all. Most of the others are wider, so they influence the minimum size of the base.
-- Gordon
The width of the robot is the same front and back, as the motors and wheels are inset to provide a straight contour. it just looks wider on the caster end because of the perspective of the photograph.
In general robots with a single caster on one will track (travel in a straight line) better when the caster is in the rear, so it acts as a tailwheel. (Nosewheels tend to act as steering wheels if they don't re-center well, though this isn't usually a major problem with casters that are 1/2" wide.) Wide or narrow base front or back shouldn't make much of a difference. Extremes notwithstanding, you can alter the shape of the base to provide a little visual distinction to your bot. Rover was made to be reproduced with simple straight cuts, and is the type of base you'd make with a budding robo-builder.
-- Gordon
I know that over volting will reduce motor life, but I can just buy new ones for a few bucks, so I'm not concerned.
But kindly note that I'm getting excellent control using CR servos with SPUR gears here! (Never mind the controller) http://www.youtube.com/watch?v=PfMnl4oGzs8
Since the worm gear dates back to Archimedes, and he made all his robot in wood, I think the two go together.
Nice proof-of-concept with the servos, BTW. I'm too lazy to hack into servos to that degree, but it's neat to see that it can be done.
@Martin: 336:1 seems awfully slow to me. However, you'll probably be able to haul around your cat on top of the bot.
-- Gordon
[At Hack-A-Day it'd be: The data show that "over volting" reduces motor life quite significantly.]
Since you're rolling in cash, why don't you just shell out for the 6V-ready versions already?
-- Gordon
The case size & shape are just the beginning of motor variations. RE-class economy motors look just like RC-class motors, but the brushes are vastly different (RE=stamped metal, RC=carbon brush, heavy duty), several different windings may be inside, some have oriented magnets or different commutator timing for better performance in one direction.
@Gordon, the RC-260 RA comes in several flavor windings:
2670: Istall@4.5V=6.8A 70 turns of 0.26 mm magnet wire
18130:Istall@6.0V=2.61A 130 turns of 0.18 mm magnet wire
10350:Istall@12V=0.67A 350 turns of 0.10 mm wire
08450:Istall@12V=0.33A 450 turnsof 0.08 mm wire
Should have about the same stall current as the RC unit above at 6V, ~2.61A
Browse THIS! http://www.mabuchi-motor.co.jp/en_US/product/p_0303.html
You'll find other RE-260s on Alibaba, but it's the same thing. "Minimum quantity 10,000 units." I only need two.
-- Gordon
Just thought I would share the find.
-Ron
