What happened to Kye's RS232 Communications Engine? I can't find it anymore.
Somewhere, somehow, some weeks ago I downloaded a copy of Kye's "RS232 Communications Engine" and today I was hoping to run a test with it to echo some data from a Propeller through a Max3232 chip, the same kind of chip used on the Propeller Professional Dev Board for RS232 communications. But now I can't find Kye's code anywhere on the OBEX. Not even Google seems to be able to find it. So now I'm wondering: where did it go? Did it get yanked for having problems? Is it buried in some other OBEX file?
I have a few questions about how to use it, so I would like to link to it.
Here's the header from the copy I have:
{{ /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // RS232 Communications Engine // // Author: Kwabena W. Agyeman // Updated: 7/27/2010 // Designed For: P8X32A // Version: 1.6 // // Copyright (c) 2010 Kwabena W. Agyeman // See end of file for terms of use. // // Update History: // // v1.0 - Original release - 1/2/2009. // v1.1 - Made code faster - 2/18/2009. // v1.2 - Reduced code size by more - 3/27/2009. // v1.3 - Increased maximum speed - 7/15/2009. // v1.5 - Fixed timing errors and continous transfer errors - 8/30/2009. // v1.6 - Added support for variable pin assignments. - 7/27/2010. // // For each included copy of this object only one spin interpreter should access it at a time. // // Nyamekye...
I did a search in the OBEX with the keyword "serial" and then search for "kwab" like kwabena and came up with this
http://obex.parallax.com/objects/397/
keep the questions coming
best regards
Stefan
Yes! That's it! Stefan, thanks for finding this. It never occurred to me to search for "serial." I'm clueless about RS-232 so I didn't know what else it might be called. I was worried it had been retracted because of a problem or something, so it's a relief to see it still exists.
thank you!
eek! I didn't see that. I guess I'll have to look at using one of the other serial drivers.
thanks for pointing that out to me!
LOL. Now that is a very good question.
And the answer is:
And my response:
Bruce
Well, Bruce, I took your advice. But for some reason things don't seem any different to me.
However, I heard Kye fixed his RS232 software mentioned earlier, so I'm excited about trying it out, glasses or no.
That is a completely new look for you
Yea, I see he fixed two drivers. He has been busy.
Bruce
